I made some research and it looks like Kuzma 4P 9 will fit the bill for my LP12. It can be done and with 920g of weight the bounce is still nice.
Booker, on the other forum when I posted a thread about the importance of Azimuth adjustment and asked why the ‘best’ Linn arm doesn’t include this...I was told the following..( with considerable insistancy and some amount of frustration with my OP, lol):
The Ekos Se doesn’t need to include Azimuth adjustment, because only faulty cartridges from the factory don’t have their stylus aligned in a correct perpendicular manner! As such, adding another connection or adjustment would interfere with the arms rigidity.
Now on the face of it this seems like a crazy point of view, however, on some reflection I actually wonder if that is a very valid point! Therefore, why are you so concerned about your Colibri cartridge vs. other MC’s in this regard....isn’t the build accuracy sufficient to not have to concern oneself with Azimuth adjustments?
Just curious as to why you believe in the requirement for Azimuth adjustment..and I suspect it is for a very good reason.
OTOH, could it be that Van Den Hul’s Build quality suffers from some lack of QC...as the other Linnie basically insisted.?
Unless we have real data with a significant number of samples of each cartridge this is just high-end gossip. But rumors start in this way. In the past some people had quality control problems with vdH cartridges. In Europe we sent them back to vdH and usually two/three weeks later we get them properly aligned or repaired. If other countries distributors have poor support it can be a problem. I have owned a few van dan Huls and never had a problem.
Systems having high resolution usually need more care in set up and show the effects of this care more easily, so we will have more opinions on them than on less resolving equipment. Surely there is an higher possibility of Colibri owners thinking about azimuth adjustment than from other inferior cartridges ...BTW, I will send the Colibri to the factory for realignment after 300 hours - it is part of the purchase.
Disclaimer - my Colibri Master Signature sample sounds so good without any azimuth adjustment that I forgot about it. But some time in the future I will carry it .
Micro, I am simply reporting back as to what I was told on the other forum. I'm not saying that Van Den Hul cartridges have QC problems...I have absolutely no idea. OTOH, I can see the point that this forum member ( Linnie) was getting at, at least in theory! That is, IF the stylus is 100% perpendicular in the cartridge body and is aligned correctly, then what is the purpose of having an azimuth adjustment? Since this question applies to ALL cartridges, and not specifically to Van Den Hul's, then i would think it could be apropos. Now I do agree that the more resolving the gear, the more potential for SQ diminishment in the event that the stylus is off even the smallest fraction, resulting in a need for said adjustment. Same for the output from each coil...but again, I think one could argue that this still boils down to a QC problem. One that maybe is expecting too much from the cartridge manufacturer...but that is entirely another question.
My question to you is...do you think that the Linnie has a point?
What is actually definition of the Linnie? To me this is a person that uses all Linn equipment and does not consider anything else.
I remember I started discussion there on Kuzma 4P9 but that was not related to testing this tonearm and rejecting it for its bad sound as you wrote above. It was discussion if it fits or not LP12 nothing more.
Hello there,
I need to correct the above as I am proud to announce that now I am the happy owner of Kuzma 4 Point 9 tonearm! I just installed it on my Linn LP12 w/Keel and I can tell you this: this tonearm is very special. Works beautifully on my LP12 and gets my beloved VdH Colibri to voice more than ever with total control of this difficult cartridge. Here is the picture: https://www.dropbox.com/s/tmgd7tq54yp37wk/Photo Sep 19, 12 28 13.jpg?dl=0
