I recently finished yet another head preamp and it is now fully tested and calibrated. Since I have the Otari MTR-12 and Studer A80R sitting side-by-side, both with direct outputs, I added the input switch - space is becoming scarce and I wanted to use one preamp with these two machines.
Naturally a question popped up - which one would produce better sound? Both machines are in excellent condition, their heads have low to moderate wear, just a bit more on Studer, but both have perfectly shaped wear patterns.
Their heads designs are somewhat different. The Studer has butterfly heads, and Otari - what I would call the truncated butterfly, with wide guard band, but poles forming a shallow X, their points slightly trimmed.
Ideally for such comparison two identical tapes would be best... which I didn't have... but I had a superb 2xHD La Network tape and a safety copy, made on my best dubbing setup... so I decided to run it one way and then swap the tapes.
For the first run the original tape was on the Otari. It did not take long for me to realize this setup produced far better sound. But one big variable remained - could that be the copy's lower quality?
So I swapped the tapes and the result was - Otari still sounded better. At this point I realized that I forgot to check the gains - as we know, we tend to prefer the louder sounds.
I put the test tape on both machines, and bummer... Studer was louder by full 2dB. It also had just a tiny amount less noise.
Interestingly, the sound quality the Studer produced immediately reminded me of the typical Studer sound - something I never liked, but that people typically assign to their electronics contribution.
However, if this experiment has any validity, it means it is the heads, not the electronics, that dominate the Studer sonic signature.
The Studer still remains one of the most pleasant machines in use and its fast rewind pack is as perfect as I have ever seen.
Would putting the Otari heads on a Studer produce the best possibly playback system? I am afraid the answer to this question is going to remain a mystery.
But one thing is certain - with Otari's available for a small fraction of Studer cost they do make one hell of a bargain.
