We typically think of bi-amping to power loudspeaker drivers directly and/or to power one driver of the loudspeaker with one type of amplifier and another driver of the loudspeaker with another type of amplifier (such as solid-state on the woofer and tube on the midrange/tweeter*).
Bi-amping also can be used conscientiously to change the relative output of one driver versus another driver. This gives the user great flexibility and control over the overall tonal balance of the loudspeaker.
If you feel your upper bass to lower midrange is a little thin and lacking in weight or impact, configure your system so the higher gain structure amplifier is on the woofer, and just raise to your subjective frequency response preference the attenuator that is in-line with the woofer amplifier.
*There is a school of thought that this is a terrible idea because the difference in amplifier topology will be heard as incoherency between the loudspeaker drivers, or as phase or timing anomalies. While I respect this view, I personally have never heard this incoherency or any anomaly.
