I have to limit my choice for 3-4 amps. I did a little research and I'll get to listen MP-M201, 911mk3, Gryphon Colosseum or Mephisto. The NHB-458 will be tough, but I wonder about ordering without listening session... Big cojones?Maybe
But I don't think that I'll be disappointed. If Dartzeel will be not good, I'll sell this amp with a little loss in value... I hope
Hi Elberoth,
It's nice to see you here
As you know, on "our" pl forum it's hard to get reliable information and sometimes it doesn't brag about what you listened to, where, and what is your opinion about it.
I order my Q7s soon (next week probably). I start to built my listening room at the moment.
Back to Burmester - still one of the best one-comapany full system I've heard. IMO better than more expensive Soulution, which I thought as the best recently.
Yes. Everything balanced I've tried sounds better using the Interocitor to go from single-ended to balanced than just using the shorting plugs. You have to try various switch settings on the Interocitor - because depending on the different grounding on the preamp and the power amp, ground should be floated or shorted.
Going the other way, balanced preamp to single-ended power amp is much more variable. Sometimes it sounds better, sometimes it sounds worse.
I even tried balanced to balanced and single-ended to single-ended using the Interocitor, and suffice to say, it is now permanently in my "bag of tricks".
Hi Microstrip, thank you for answer. So, what I should do ? Is it any way to test if DC component is present in the mains? Is it possible that amp is noisy due to age ?
I agree with microstrip. Age probably has nothing to do with that. My older 911mk3 is now 9 years old. The burms are amongst the quietest electronics but I think they are susceptible to interference from other equipment around them, especially TVs. My amps hum only when the TV is on. It is almost negligible now after I installed a Bryston BIT 16 power conditioner. So, microstrip's suggestion of a power regenerator is probably the right way to go. You could also install an isolation transformer like the Torus or the Bryston, which I have and successfully reduced the hum. To reiterate, though, it only hums a little now when the TV is on but I don't usually have the TV on when I am listening to music. So essentially they are dead quiet. You might want to first check if you have noisy equipment around and then turn them off and see if the hum persists. In any case, installing a regen or a trans should help immensely.
Cheers
Thank you, I will try to investigate source of interferences. Friend of main has large isolation transformer I will borrow it for test..
In the meantime, I have another question how hot 911mk1 should run after few hours of listening to music? My has only 28 Celsius on the left radiator and 30 Celsius on the right. Seems lite bit low. Perhaps the bias is set to low? I wonder if some one could share with me bias setting procedure ? (I'm relatively experiences in DIY and I have all gear from signal generator to oscilloscope)..
Regards
