Busting Martin Logan Myths
When I tried out a pair of hybrid MLs I was using a pair of EAR 509 moniblocks (100 push pull pentode) though I guess may have been a bit anaemic for the task compared to some monster valve amps around.
In my experience I would say that that amplifier is a little bit light for the job. I used 750 watts push-pull pentode.
Potentially explains a few things :D
I know Martin-Logan says otherwise, but I wouldn't be at all comfortable unless you could throw at least a couple of hundred watts at them.
Reactions: bonzo75
(...) Without exception I personally have never liked the sound coming from any Martin-Logan speaker I have ever heard when it was driven by a solid-state amplifier. For whatever reason, to my ears, Martin-Logan electrostatic panels require high power for dynamics, and tubes for tone and naturalness and to put a little meat on those electrostatic bones.
I had your opinion until I listened to the Monolith III's driven by top Mark Levinson with Transparent Audio top cables sometime in the 90s. I had to swallow my convictions - a meaty sound, but not fat, with plenty of transparency and presence, great slam. Later I listened to ML's sounding great with NEMO Electrocompaniet power driven by a tube preamplfier and the Krell's KAS200.
IMHO the most critical point of ML panels is the room - in some rooms we never manage to make them sound good, in others almost everything sounds great on them.
I to prefer ML sounding transparent and steady with a good SS amp. I prefer the valves upstream.
The Gamut I tried was much better than the AR Ref 110 i owned on my Summits, or the ref 610T or 150 that I tried on the summit X.
And yes, for ML room is much more important as is the sweet spot which is the thing I have against them.
