Where should I post the instructions?
Just out of curiosity I will be taking frequency response measurements of my system with Litz wire speaker cables when new and after burn-in. The Litz wire has a ton of surface area and burn-in is very dramatic so I do expect to see a before-after difference in both FR and sensitivity. If anyone has other measurements they would like to see let me know, I only have a 5.5 digit DVM and Dayton isomike measuring system. I am super busy so this won't happen immediately but within the next few weeks...
I feel like this Litz wire speaker cable is an ideal example of burn-in so I'd also be willing to send 2 sets of cables, one burnt-in and the other not, to someone... preferably a skeptic... who is trusted to give an opinion with minimal bias and report back here on their subjective findings. If they wanted to take measurements as well all the better. I can have these test cables ready to go in a couple weeks or so. Anyone interested?![]()
How about Gary's suggestion in post #69?
Suppose the cables keep burning in, and the Frequency response keeps changing , how will you stop them 'burning in',
what if the sound is dramatically worse after the 'burn in' can you burn them 'out' we need to know!
Keith.
This would simply be a measurement of lag from input to output and may take sensitive equipment (which I do not own) to measure. And correlating results to what is heard may not be obvious either. Keep in mind what equipment I own, if you want other tests done you must send me the test equipment.![]()
You will not find measured differences in frequency response. You will need to test for energy storage and release. These are difficult to measure. Or, use an impulse response test and watch the trailing edge for subtle ringing and overshoot on the rebound.
I'm not so sure about that, my hypothesis is the litz wire has so much surface area and the burn-in is substantial enough that it will show up on a FR plot.
Lizt wire cables typically use a low quality insulator (varnish or similar) and additional Polymer type insulation - I would not expect them to be sensitive to burnin.
From what I have read on others experience, Teflon cables are some of the more sensitive to burn-in. Just a feeling, no proofs!![]()
Explain to me by which physical means does a cable 'burn in' ie what changes?
Keith.
"I can guarantee you the effect is WAY beyond being explained by placebo effects or expectation biases."
How did you arrive at this conclusion?
What proof do you have that cable 'burn in' exists?
Keith
I'm hoping to provide some measurements that will show it clearly. We will see if it works out.
Rob,
First wonderful job and thank you so much for taking these measurements. Would I be imposing if I asked you to explain how to read the measurments, for many on this forum have no clue about anything technical, as their ears are the only measurement tool they have!
You know, how at the end of any technical graph you explain in simple English what the graph is telling someone, what it means at one extreme and the other type thing, mainly the waterfall and ETC plots I think. .
