All wave guides provide a little gain. If they didn’t you would never be able to cross them over close enough to a woofer .
Dear TangI don't really know about how much my speakers fall short of the very top vintage. Maybe it does may be it does not to my ears if I have a chance to hear the holy grail vintage horns. But ddk is right that with mush much less money I spent on my Cessaro I could definitely get the horns in my radar that could have as excellent sound or better than my Cessaro. (Not the Living Voice because I don't think they sound better than my Cessaro.) The thing about big Cessaro is once you buy it you cannot sell it. It is too big, heavy, expensive, require large size room and Ralph to assemble and disassemble it. People who wants to buy a big Cessaro are well to do that dont buy used modern audio either. You buy big Cessaro you are stuck with it...luckily they come with excellent sound. Audioquattr understand what I am talking about.
If I want to construct another system from scratch right now, it will take no more than one fourth of what I have been spending in audio gears for the last three years. And the sound will be no less good than what I have right now. For less than $100,000 you can even get the vintage horns system with the required amplifications with potential to be one of the best if you know who to talk to.
Tang![]()
OMG, are those 1600 etc. inches?
Yes, I now remember, when I asked the designer of my speakers (Reference 3A Reflector) why they had more treble output -- a good thing -- than my old ones (Reference 3A DeCapo BE), he said it was because of the tweeter waveguide.
Yeah. Unfortunately proper horn loading just needs a lot of horn. So no normal folks (me included of course!) can really ever experience it. Imagine a 20hz horn - will need to be humongous.
"It's hard to say if there is an increase in overall power as a result of improving mechanical impedance match with air as horns do, or if the output is simply concentrated as a result of the directionality the waveguide imposes. "
Depends on the type is it Constant Directivity or is it relatively flat on axis.
If it is CD then you need electrical EQ to counteract the mass roll off in a compression driver. If you use electrical EQ with a CD horn/ waveguide you get even coverage across the entire bandwidth and a relatively flat power response.
If it is flat on axis with no EQ what you have is the horn/waveguide that is using directivity to compensate for the mass roll off so what you end up with is a falling power response with quite pronounced beaming in the upper octaves
Rob![]()
If it is CD [constant directivity] then you need electrical EQ to counteract the mass roll off in a compression driver. If you use electrical EQ with a CD horn/ waveguide you get even coverage across the entire bandwidth and a relatively flat power response.
Rob![]()
Hello Duke
Thanks, I agree with that and you can see it in measurements. If you go through on axis sensitivity measurements of horn families where the directivity changes you can see what you suggest. We used to call horns long, medium and short throw. Where the long throw were narrow directivity patterns, short throw wide and medium would be a hybrid between these extremes.
Take a look at this data sheet.
http://www.lansingheritage.org/html/jbl/specs/pro-comp/2360-series.htm
The 2360 is 90x50 and the 2366 is 50x27 so very close to half and sure enough the on axis spl difference is 5dB. These are CD horns so you have uniform coverage after EQ.
I like short throw CD horns over traditional flares such as a exponential.
Rob![]()
You have some cool looking speakers on your page! Some of them are a bit Roy Allison to me. Make the room work for you.
Do what I did so I could run a 98db woofers cheat as in Bi amp. Its a balance once you start driving woofer efficiency up sooner or later the last octave just drops out.
Have you looked at the newer ring compression drivers. They seem to have more output up top.
I am sure you know about Earl Geddes Summas Not sure what his system sensitivity was but that design seems to be what you might be thinking about. I think his Oblate Spheroid wave guides were 60 degrees??
I am sure you know about Earl Geddes Summas Not sure what his system sensitivity was but that design seems to be what you might be thinking about. I think his Oblate Spheroid wave guides were 60 degrees?? Hard to find something like that off the shelf so to speak.
Parkcaka, I am with you 100%. I had the good (bad*) fortune to hear the Roma model @ Rhapsody in NYC a couple months back. I currently own Alexia (v1) and like you I have loved the musicality and overall delivery. But the Diesis changed my perception and my expectation of what to expect from a speaker. I was more impressed with what I heard from the “Roma” model than I was listening to the Wilson WAMM. That is not a comment of technical virtues, just the impression the speakers made. Lifelike realism, an uncanny ease and flow to the sound, instantly engaging and not requiring monstrous power (ala Dag’ Relentless). Simple form factor, decent WAF, and then the sound...
Did you compare the Caputi to the Roma directly?
* I only say “bad” with respect to the fact I now have to find a way to put Roma in my own room. Fortunately the Minister of Finance is warming to the idea, slowly.
