I heard a much smaller VS speaker in Munich, I was impressed, one of the better rooms there in my opinion! It is likely these were very impressive at the Capital AudioFest.
I'm surprised folks would schedule an audio show in D.C. right after what turned out to be an "eventful" election in the US. I'm not surprised attendance was down. I chalk it down to folks busy either celebrating (!) or commiserating, both with copious amounts of alcohol.As an exhibitor my feeling is the attendance was definitely down . The reasons are for me only speculation however I would guess the dates had something to do with it
Err ,,yes really ..!Errr ,,Not really ..!
One just needs an SS amp which can drive a big capacitor , there is no way your OTL is gonna drive the 2-1 ohm load in the highs like it does the bass at 25+ ohms...
This impedance tilt means the OTL drops to squat for power in the highs but not so in the bass regions boosting the bass Drive.
A perfect impedance storm for an OTL and opposite to what a constant voltage source SS amp would do driving the speaker with power across the full bandwidth ..!
The capacitive load of ESLs does not respond to the Voltage driven rules that most box speakers do. The capacitance at low frequencies is a high impedance and drops with frequency, but the power it needs to make sound pressure remains constant. The speaker has a double peak on account of dual matching transformers, one optimized for bass, the other for highs, driving a single full range panel. So those peaks of impedance do not represent portions of the impedance curve caused by resonance (there's no box to cause it)- so if the amp dials back power into those impedances (for example in the bass) then the power of the amp will be limited as a result and also bass shy.
We been driving Sound Labs for decades and shown with them multiple times at CES and THE Show (where we obtained Best Sound at Show from Dick Olsher). We have lots of Sound Lab customers and over 85% of our MA-2 production going back 30 years has been for use on Sound Labs.
The saving grace of the Sound Lab is there are backplate adjustments to allow the speaker to work with amps with different Voltage response to load. So you can adjust it to sound fairly good with solid state amps, but those amps don't make power easily due to the high impedances. The decreasing impedance at high frequencies is tricky on any ESL/solid state combination since most ESLs (Sound Lab included) vary by about 9:1 or more (Sound Labs about 10:1 to 20:1 depending on the position of the Brilliance control) between the low frequencies and the high frequencies. This means any amp that can double power as impedance is halved is going to be making too much power in the highs. That is why the Brilliance control is provided on the Sound Labs.
Please do not try to gaslight me further...
That depends on the size of the OTL. Sound Labs like a bit of power so a bigger one is needed anyway. In the case of the MA-2, it will make nearly the same power into 24 Ohms as 8,16 or 32 Ohms (its power is slightly decreasing as impedance is raised from 5 Ohms where it makes its highest power output, but only by a few Watts). So it still makes significant power into 2 Ohms, well over 100 Watts.Irony Noted ,
Yes SS bass shy vs OTL high freq shy when using an OTL , its not from superior bass of said OTL ..!
The end ..
BTW whats the power output of your OTL amp @ 24 ohms vs 2 ohm ..?
TomiAny favorites of show from those who attended?
Perhaps a notable mentiTom,
In case you're new to the show, the day to go is Sunday if you want to hear the rooms at their best. The biggest problem exhibitors face at shows is the room and usually they are figuring out how to make things work all through the show, even if they have been in the same room multiple years.I went with a short list of products that I really wanted to listen to, and the lower attendance from previous years meant that I was able to get some good time in the sweet spot with my little bucket list...
Maybe controversial, but:
I'm a big Apogee fan but the Clarisys Audio speakers sounded cold and hard. Lifeless.
I'm a panel speaker fan and while the big Sound Labs have wonderful tonal qualities, I couldn't live with their larger-than-life images. (Bloated).
The new Altec Lansing speakers - what, no horn drivers, really? And their 300b amps looked a lot like the ones on Ali Express, something that was brought to my attention by a number of folks in the Altec Lansing Facebook group.
I've never heard a Von Schweikert speaker sound great at a show. Nothing I've heard has ever made me think that I'd like to own one.
The big G.I.P horns sounded quite meh and the cabinetry looked very D.I.Y, whereas the Semrad Audio horns were $20K+ less expensive and sounded/looked way better.
I didn't expect to like them and I didn't want to like them, particularly, but all of the YG Acoustics speakers I heard sounded very good.
The Quads were a disappointment in the Robyatt room. There was something a bit hard and brittle about the sound that I didn't expect from Quads and something I've never heard from the 57's I've owned, unless I've over-driven them.
MC Audiotech's speakers were very good indeed, nicely balanced top to bottom and musically engaging.
Songer Audio - another world-class showing, they sounded even better than I recall from the previous show, in 2022.
Maco speakers - these open baffles using the Lii F15 drivers were shilled by a couple YouTubers and sounded bang average. They're fine on simple acoustic stuff but hit that driver with anything complex and crank the volume and the whole illusion falls apart.
I've read a lot of show feedback on various forums and realize that I'm in a minority with some of my opinions above, which is just the way I like it.
Looking forward to going again next year if I'm still around.
It's my third time at CAF and I was lucky enough to spend the full 3 days. It was very enjoyable, particularly the live music in the hotel bar on Saturday evening.In case you're new to the show, the day to go is Sunday if you want to hear the rooms at their best. The biggest problem exhibitors face at shows is the room and usually they are figuring out how to make things work all through the show, even if they have been in the same room multiple years.
This sounds quite unpleasant after a while, other rooms recorded by Jay, like OCD Mikes, sound good. In this case I suspect the track used is not a good recording.New Von Schweikert VR 30 Loudspeaker With Horizon 360 DAC & WestminsterLab Amplifiers
Yes, this guy played those Popori speakers with some horrible bass "record" , at very loud levels, made my ears bleed within 10 seconds, I literally had to run out of the room. Every time I attempted to go in they played something truly awful and devoid of any musical value, just to claim that those speakers could do bass. That they could, however after visiting that room 5 times, I still have no idea how those speakers sound at normal to my ears levels (about 85-90 db). THe forte of any electrostats is their 'magical and pure midrange. There was almost none in that room. This has got to be the WORST DEMO AND INTRODUCTION OF THIS TYPE OF SPEAKERS I HAVE EVER HEARD! I was not alone in my assessment either. The presenters whomever those were must be deaf at certain mid range freq, by my estimation . The presenter here claims they have sold 3 pairs, judging by the audience size in lot of rooms at the show, there was no shortage of semi-deaf audiophiles.
