NorthStar;217516 As for CD; it is just fine said:The mastering/remastering matters more in my [very] limited experience with hires than the final format. MA Recordings is wonderful, as are the many labels you list above. Apples to apples, best to best, I can imagine hi-res is stupendous, but practically speaking I look at my music collection and I am not sure that much of it is available on true hi-res (vs a re-labelled upsampled 16/44 if at all).
Can't get those files...requires username and password
Really? What thread have you been reading? It can't be this one. The thread you are referring to must be posted on digitalutopia.com.
Just for reiteration; in case few people missed it.
Well the file info on both files says 24bit so??
Rob
An audio signal’s amplitude more or less correlates with its loudness or volume. The bit depth of the samples determines how many steps there are between the quietest and loudest possible sound that can be stored in that digital signal.
If there are too few steps, the signal gets “steppy” and sounds like a sequence of discrete notes rather than a smooth gradient.
One is 24 bit native. The other, 16 upsampled to 24.
CORRECT ME IF I AM WRONG:
16 bit audio >>>> 65,536 possible levels.
24 bit >>>>> 16,777,216 possible levels.
And if the sample rate is 44.1, then you have 44,100 slices per second. Therefore, in 0.00002267573 second the music reproduction has @ 16 bit a choice of 65,536 possible levels of depth.
That appears to me to be some Extremely Tiny Steps.
zz.
zz.
zz.
zz.
