Today at home if my friend with Wilson Alexandria we tried CH A1 mono vs his amp Viva Aurora mono,very good tube amp with tube 845.
Viva is considered one of the best tube amp in the world,and his sound is very good,but we found CH better in every parameter.
We were in 3 and all 100% agree
Sound was more dynamic,bigger image,bass more controlled and clean,high more open,more transparent and also voices were more natural and sound more fast
Regards
Gianluigi
Mike will produce most natural vocals by letting the recording show through with SS. Ribbons when driven properly, with SS gear will produce superbly natural vocals then if under driven by triodes. Also, as mentioned in the compare between VTL and spectral, while VTL had more harmonics, it made the singer's sound seem half open, while with spectral the singer was opening the mouth wider, which was more natural. Also check with Marty for impressions on vocals when he moved from Siegfried to spectral. The Gamut sounded better on my Logans for vocals than the AR ref 110 because it was driving it better rather than fuzzy. High end triodes are fine if used on horns. All imo.
I was listening to Monte Verdi's Vespers at sheldonian last Friday and was thinking that the only speakers capable of producing such vocals, like with Bach's st Matthews passion, are Christoph's scintilla driven by Krell. No set horn I know can do that, though I prefer many instruments on the latter
The yamamura Gian writes about is driven by SS
Is worth noting that Avantgarde also use sand amps with their horn speakers.
I already told I listen music always with display at 0 watt or arrive Maximo at 1/2 watt
Sometimes I listen some At loud level
100/200 watt peak with blues and is good
When I listen chamber music Maximo I see 1 or 2 watt
I will reply more fully later, but where, for you, do hybrids (e.g., KR Audio) fall on this naturalness of vocals taxonomy?
