I have only recently joined this site and came across your section of the site, from your obvious experience i would greatly appreciate your ideas on the best direction to go with a dedicated sound room build from scratch.
Currently there is a concrete slab 600mm thick with an available area 11 meters x 9 meters x 3.5m high although this is not an issue just allows me to conceal all the aircon and filter system above the ceiling area and still maintain the 3.3m ceiling height.
My current thoughts ( and I am very open to suggestions ) are for walls external in solid brick with a 300mm cavity then internal solid brick or split block textured face masonary approximately 150mm thick. The cavity once all the services are run would either be sand filled of rammed earth filled to provide the density for a fully sound proofed room.
I have a number of speakers in mind the top of my list would be the Rockport Arrakis but I would ideally like the room not to be the limiting factor in whatever I select now or in the future. I do have the option of making the end of the room one half of an Ocatgon shape as this would match the style of the rest of the house but I am unsure if this would be an acoustic advantage.
Obviously the room would require further treatment from this finish point to obtain the best neuteral overall match, I am currently installing a 10-15KW solar system so I don't have to feel guilty about the power I consume along with dedicated high grade supply into the room so power won't be an issue.
Any comments or suggentions based on your experience would be welcome, I thank you in anticipation of your reply.
