Computer Audio: confusing, complicated, & INCONVENIENT. About MUSIC or inner nerd?
Weve had that conversation, mike, and I believe my gear is listed in my profile. It represents a completely different approach than what most here have taken, a very inexpensive one compared to some, but I'm confident that it is good enough to make some observations, reach some conclusions...you know, have an opinion? That's all I've expressed here. Is that a problem?
Tim-If I read the specs on your speaker correctly (and your DAC is built into your speakers), the DAC is capable of decoding 24/192. However, since you listen through iTunes, you can't get there from here. Aren't you stuck listening at 16/44.1 with iTunes?
Gentlemen, great stuff.
Did anyone buy a Playstation to rip their SACD's? And what about the DVD-A's?
I did. Still to use it though. Soon will
+1. totally no idea...I originally bought my DAC 7 years ago to do a server when everyone thought I was nuts...but when I realized how much was involved (which hard drive, hooking up an automatic raid or redundant drive, a server, an interface, you have to hook it up to internet just to get the names of the songs/artists, otherwise its all blank?, plus music playing/copying software, what kind of rip rate or whatever, there is XACT copy or something that is a better rip but it takes longer to do...I realized it was not for me for now.)
Honestly, the Meridian Sooloos is crazy expensive but is probably meant for dummies like me.
Not really, if you contact Item Audio he will come over to your place and do the whole set up for you. With a modded desktop or the Aurender, depending on if your dac is sensitive to USB or SPDIF (easy to check), and voila it will all be up and running. Aurender works out of the box without any complications. If you are worrying about all that hard-drive, anti-raid etc you have mentioned in your post, than all you are doing is reading too many forum posts. The Aurender should sound quieter than any CD player, incredibly smooth, powerful and dynamic. Setting up computerized audio is almost instantaneous if you know whom to call.
The iPod is stuck at 16/44, but ALAC can encode higher.
As far as I know iTunes doesn't have this limitation.
If the connection is Toslink (AMD9 are the speakers if I remember correctly) it is limited to 24/96 max
That's what I thought, but when I looked up the specs, it said 24/192.
I think iTunes is the limitation (24/192 through USB, 24/96 S/PDIF), although that may change with the next update (I'm only guessing, no insider info)
Edit: with the right hardware, I think iTunes can do 24/192 over S/PDIF also, but I have no personal experience.
No, iTunes can play 24/192, but it will not switch to native sample rate automatically. It would be a pain if you played much hi-res. Fortunately, aftermarket players like Amarra, Pure Music and Audirvana will do that if you need it.
Tim
(...) what might be helpful to the rest of us 'uninformed' and 'deluded' listeners would be for you to tell us specifically about your listening comparison between 16/44 and 192/24, and then between 16/44 and dsd and 2xdsd. tell us about the specific gear and specific music so we can all understand your 'much subtler' comments.
i realize that is not going to ever happen. but at least i had to ask.
have a nice day!
Mike,
You will almost never get an answer about real experiences with real music or any details from several of our members. I have found they love speculative debates, but hate real life. It seems we, the "deluded" and "uninformed", are often guilty of our practice of exchanging opinions about how the music sound in our systems in a non scientific way. :)
Mike,
when I challenged Tim about his dismissal of the benefits of hirez, I had no illusions that he would response with any substance, and he did not disappoint me....
when he asked me to 'move on', I decided not to extend the dialog with further engagement. so I said.....
not at all, enjoy the day.
I simply had better things to do with my time. I had rocks I had to remove from the treads in my tires. it was much more fun and satisfying than trying to pin Tim down about his alledged specific listening experiences.;)
Just a reminder, gents, this is the post you're talking about....
Audio memory can be very flawed, even over relatively short gaps, but I doubt that's the real issue. If you had the Redbook CD and upgraded to the remaster, at 24/192, or any other sampling rate, they're not the same master. It was "re-mastered" for hi-res, so they will sound different even if they're the same resolution. The simplest way to compare, if your software will do it, is change the sampling rate of your 24/192 remaster to 16/44.1, save a copy, then compare exactly the same recording at the two different sampling rates. Then of course you have re-sampled and copied, taken it down a generation and reduced the rate to 16/44.1. All good sense says there should be an audible difference, and there probably will be. But I'd bet it'll be much subtler than you expect. Maybe so subtle that in blind comparisons you'll have trouble telling which is which.
A post in which I did not dismiss hi res, and I did describe a specific experience. The missing link was the gear used. I referred you to it, in my profile, in a subsequent post. I don't know what you guys want...well evidently it is unqualified agreement you're looking for because a pretty benign discussion of possibilities that might contradict your position set you off on a public discussion of the person who dared to question. Bad form.
Tim
Tim
no; this was the post;
Someone probably would, but not me. I believe 24/192 should sound different from 16/44.1. But I believe the difference will be much subtler than most audiophiles conclude with their eyes open. And blind, I'm not sure you'd always pick the 24/192 at the better example...
Tim
and here was my response to it;
and btw; I have about 10 Reference Recording CD's where I also have the HRx 176/24 master file on my hard drive. the CD's use those HRx masters as their source.....which is essentially what you are suggesting with that earlier post.
it is quite quick and easy to do that comparison all day long, I've done it many times and it is child's play to pick out the redbook. I do expect that as you go down the road to the most modest digital players that there may be a point where you find gear that won't tell you much (enough?) about the difference between those different digital sampling rate levels. and you might be there with the gear you list, I really don't know....but it's possible. I'm not being elitist, I'm simply stating probability.
Phelonius writes :
Where's the experience eg. Listening?
Again not to mention Bruce has already provided REAL samples making your suggestion moot and flawed.
Maybe there needs to be a point of comparison to facilitate better understanding.
I don't think anyone said there's NO DIFFERENCE between redbook and the higher resolution version from the same master. However, the differences between higher sample rates are minor compared to many of the other parts of music reproduction in my room. Things like the room itself, the speaker position, type of speaker, bass dynamics and linearity and seated position. If one's room has gone from mediocre to great in any or all of these factors, then higher sample rates from the same master really are trivial and mostly unimportant to music enjoyment.
It's in this context that I judge high resolution. High resolution and especially DSD can and is intimidating to many computer audio neophytes. DSD also greatly limits bass quality because DSD prohibits use of DSP, which is essential to excellent bass linearity in most rooms. I have personally gone down this high resolution road using some of the "best" DACs available in a very good room with great speakers and amplification. In the end, I've come to mostly the same conclusion as Tim.
Michael.
Wow...good to know. I had read good things about the Aurender. Thanks for that.
Are you guys actually reading the posts you're attacking me for? In both the posts mike has cited I said I believed there is a difference between Redbook and hi res. I just said I thought the difference was subtle.
A three pronged attack and a complete derailment of a thread over "subtle?" Really? Best, I think, to take Charlie brown's advice henceforth...
Tim
The advice sounds more like Snoopy's. Charlie Brown was the kid always going AAAAAAARGHHHHH!
