I'm using iTunes.
Tim
Thanks, Tim.
I apologize for the question...it originated with a post prior to #70
I'm using iTunes.
Tim
Exaggerated? Hardly. If you think that, then there's something wrong somewhere. It's the difference between an 2014 anorexic woman and a 1950s female pinup.
It doesn't exist commercially, you'd have to "down-res" it yourself. Then if you did hear a difference someone would ascribe that to poorly executed digital processing...Have you had the opportunity to listen to exactly the same master at 16/44.1?
Tim
May not be what you are looking for butHave you had the opportunity to listen to exactly the same master at 16/44.1?
Tim
Yes but not in awhile. I do not recall it sounding anyway near this good. However, when it comes to audio and video and many other things for that matter, memory can be very flawed. If anyone want to put together a double blind test, level matched, etc., I would love to see if I can distinguish the 2 reliably. I will say that I have heard jazz recordngs of this vintage on CD that sound superb as well. Gerry Mulligan Meets Ben Webster, which I have on a gold MoFi CD comes to mind. I have that ripped onto my computer in AIFF. I will have to compare that with the Burrell recording this weekend when I have the time. The Mulligan/Webster is sensational as well.I didn't have the Burrell recording on any format and it was on sale. It was a no brainer for me.
Someone probably would, but not me. I believe 24/192 should sound different from 16/44.1. But I believe the difference will be much subtler than most audiophiles conclude with their eyes open. And blind, I'm not sure you'd always pick the 24/192 at the better example...
Tim
I must be blissfully tone deaf. To me the differences are marginal, and not worth chasing after. For step change improvement over 44/16 2 channel, multi channel is the ticket, but obviously little content with the exception of classical.
I have not heard this particular tape but have heard one 2 channel master tape of this vintage that also sounded incredible. The same is true of a 24/96 recording before EQ. Too long ago to recall actually, other than I have noted. I have been to two recording sessions and hope to get to my third in the fall when I return from the UK to hear my son record his first album.
I've heard a third gen of the Burrell vs. Chad's excellent 45 rpm reissue in my system and there's simply zero, none, nada contest.![]()
Myles, so you are saying the 45 is better in your system than the third gen?
Audio memory can be very flawed, even over relatively short gaps, but I doubt that's the real issue. If you had the Redbook CD and upgraded to the remaster, at 24/192, or any other sampling rate, they're not the same master. It was "re-mastered" for hi-res, so they will sound different even if they're the same resolution. The simplest way to compare, if your software will do it, is change the sampling rate of your 24/192 remaster to 16/44.1, save a copy, then compare exactly the same recording at the two different sampling rates. Then of course you have re-sampled and copied, taken it down a generation and reduced the rate to 16/44.1. All good sense says there should be an audible difference, and there probably will be. But I'd bet it'll be much subtler than you expect. Maybe so subtle that in blind comparisons you'll have trouble telling which is which.
Tim
At $17.50 I am quite happy to just play the 24/192 file as is! Don't need to complicate things.
Weve had that conversation, mike, and I believe my gear is listed in my profile. It represents a completely different approach than what most here have taken, a very inexpensive one compared to some, but I'm confident that it is good enough to make some observations, reach some conclusions...you know, have an opinion? That's all I've expressed here. Is that a problem?
