Thursday IS the day !!!![]()
Joeinid,
Have you ever compared the Conrad Johnson Premier 350 to the Burmester 911? What are the strengths and weaknesses of each?
good luck tomorrow!
My that is fine! Good listenin' to ya'! One observation -- isn't the power amp the one that should be on the smaller stand to the right? Moreover, that GAT just looks too sweet to be so below eye level. Just an opinion, of course, from a guy who is not exactly known for his interior decorating skills![]()
Joe, since you have 2 pre-outs on the GAT...will be interesting to hear how they work with your Burmester monos. again, RCA-XLR will be tricky...a little tricky. Pls continue to keep us posted! Enjoy!
Hi Joe,
Look forward to reading about the GAT-911 mono combination! Gryphon Audio also provides adaptors...but they specifically state they are for temporary use until you can get RCA-XLR terminated cables. It did make a big difference in my case. Meanwhile, enjoy the GAT!
I believe that 350 has Teflon caps. My Classic SE preamp took at leat 200 hours to be listenable, and 500 - 1000 to really come on song. Just leaving it on is not enough. You have to have some signal running through it for the caps to burn in. I'm sure it will come around, based on everything I have heard about it. It will be sublime!....I am not sure why but I still think the CJ 350 needs some more burn in.
Hi Joe,
Lew Johnson is quoted as saying you have to play something...it cannot just stay on. I just spoke with a senior guy at Transparent Audio the other day...he did say their cables burn in over 200 hours...and generally the ride along the way is very rocky...so he said do not judge til the burn in is complete. Could be same in your case.
In the case of the 350SA, what is your observation exactly? for example, 'slightly white' in the upper mids/treble, or hard sounding, or sometimes a little flat?
Hi Lloyd,
...some of the higher frequencies were a little hard to take. I had to turn down the volume. I am a little sensitive to systems with excess treble energy in the first place so I tend to like warmer systems. I thought hmmmm, did not notice that with the Dart 108, everything else system-wise being the same. Could it be that recording? I don't know, but my system seem "hotter" with the 350SA installed instead of the Dart 108. Some music seems to benefit from that, most music does not.
It will be another week or two before the 911 monos arrive.
