Question: and this may extend beyond treatment of bass issues- Let's assume I have my next room designed, measured and built with some built- in acoustic treatment. Then, i make a change in loudspeaker. Now what? If the room is 'right,' it is right for all purposes? i'm getting the sense that different playback equipment will excite different frequencies that need to be addressed. Does this auger for having moveable/tuneable acoustic treatement in the room?
PS Amir: i appreciate that you advocate digital room correction. My hesitation here has to do with processing the analog signal (sorry, i'm not trying to open up a debate over analog v digital). I suppose if it were from 100hz down, that would make me far less nervous than running the midrange through processing and perhaps, in your view, I wouldn't have to (although adjusting mids relative to bass may then pose a problem); right now, i have no crossover whatsoever between the amps and midrange horn.
thanks, Edorr, yes, I am vinyl only as source.Unless you're doing vinyl, this does not have to be an issue. Just get a processor with digital input and feed it a digital source (CD transport or PC audio). You can always elect not to touch higher frequencies, but in my experience the concern about messing up the mid/highs is unnfounded (I had the same concerns), at least if you use a very good processor.
(...) Since the worst nulls almost always occur for the first few room modes, there are only a few frequencies (often just 2 or 3) and moving out of the null is not unreasonable.
HTH - Don
In the case of the subject at hand, bass frequencies, the room is absolute control. You can see that in this measurement:Question: and this may extend beyond treatment of bass issues- Let's assume I have my next room designed, measured and built with some built- in acoustic treatment. Then, i make a change in loudspeaker. Now what? If the room is 'right,' it is right for all purposes? i'm getting the sense that different playback equipment will excite different frequencies that need to be addressed. Does this auger for having moveable/tuneable acoustic treatement in the room?
Not as much extension but imparting its own frequency response on top of the speaker with incredible force such that changing speakers does not materially change what is going on there.---...So the room is basically the bass extension of the loudspeaker (below 200 Hz or so).
The opposite of that is also interesting. As wavelengths get much smaller relative to the size of your head, then what the two ears hear is different. Your head also then presents a 0.4 millisecond delay to the ear further from the source (e.g. a reflection). Translating, nothing will seem like it is anymore! Psychoacoustics gets involved and the picture gets far less intuitive. I will post longer articles on this but for now, this is a good teaser .One way to think about it is to consider the wavelengths, how long a full cycle of a sound takes at various frequencies. Interactions at half- and quarter-wave points cause peaks and valleys in the response. When the wavelength is so much longer than the speaker, the room dominates the sonic picture.
@microstrip: What are the dimensions of your room? Any openings/bays or large furniture that would perturb the modes? (...).
