Dartzeel
jasbirnandra
261
22
923
Has anyone ever had a dart breakdown, what was it and how responsive were they to repair it and what was the cost involved?
asiufy
Industry Expert/VIP Donor
Jul 8, 2011
3,711
723
1,200
San Diego, CA
almaaudio.com
I've had one issue with my 108, when I was running it on 110v. The local rep. was clueless, so I contacted darTZeel directly. There, I learned that the 108 was designed to tolerate a max. of 130v. Anything more than that, it'll fry the internal fuses. And that's exactly what was happening, a couple of times a day.
Turned out voltage here in Brazil is actually 127v standard, fluctuating around 128-129, with peaks way above 130v. Of course, the 108 was none too happy about it, and was blowing fuses left and right.
So I just switched it to 220v via the internal switch, and replaced the fuses for the appropriate spec. for 220v, and now I haven't had a blown fuse since.
This 130v limitation still stands, since it's by design. All the components were selected based on a 130v max. tolerance, so darTZeel would need to revise the product in order to eliminate this limitation, and they'd rather not to do that...
What I can tell you is that the 108 plays much, much better in 220v!
The other folks around here with darTZeel gear had no problems so far...
alexandre
asiufy
Jul 8, 2011
3,711
723
1,200
San Diego, CA
almaaudio.com
Yes, so I heard :) But 220v isn't common here, so most amps arrive in 110v.
It might be common knowledge, but I didn't knew it! So once I realised that, and knew that the 108 wouldn't blow its fuses in 220v, it was a no brainer! Now even my digital is switched to 220v...
alexandre
joeinid
1,543
12
400
NY
alexandre
Can I assume you are running it on a 220V ac line (with the switch set at 220V) and not continuing to use the 110V outlet?
asiufy
Jul 8, 2011
3,711
723
1,200
San Diego, CA
almaaudio.com
Yes, switched everything to 220v, on a properly-wired 220v outlet. That took some work, but it was worth it!
joeinid
1,543
12
400
NY
Thanks!
I thought about doing that and should have when I had new outlets installed.
Occam
[Industry Expert]
Dec 15, 2010
117
1
NYC
IMO all amps sound better in 220V vs 110
A possible explanation might be that North American 220v is split-phase, i.e. balanced power with 2 110vac anti-phase legs. Those benefits specific to balanced/technical power, net cancellation of leakage currents would benefit any Class 3 component (those with safety grounds).
FWIW,
Paul
4,702
LL21
14,430
2,518
1,448
alexandre
I have heard from FM Acoustics dealer that FMA can have similar issues in UK 240V vs 220-230V in Europe.
LL21
14,430
2,518
1,448
It seems Dartzeel is very reliable and you are not getting many answers. As your thread tittle was generic I will post some pictures of a serious system using DartZeel, even at the risk of making Mike Lavigne future MM7 system look small. ;)
http://www.soundsolutionsaudio.com/forum/topic/10834-you-want-audio-this-is-pretty-flippin-crazy/
HAH!!! I had to show my fiancee... Her first comment? "Does he have a wife?" ;) I think i can tell with all certainty i am never getting these speakers! ;) (I think if i can squeeze 2subs someday, that'll be just fine!...probably will have to justify them by saying 'look honey'...we just got a front view projector so we can watch movies as a family!)
Mike Lavigne
Apr 25, 2010
12,601
11,693
4,410
just because you can, does not mean you should.;)
andromedaaudio
8,500
2,843
1,400
Amsterdam holland
LL21
14,430
2,518
1,448
