I will follow your experience with great interest?I already have Fuuga and the Dava will be delivered next month. The turntables, the tonearms as well as the preamps won't be the same but still I may have an idea in between them.
Is anyone dedicated to the Dava enough to have the cable routed in the arm.
I've got all 3 DaVa and have tested numerous arms with it, and so far the Ikeda is the best match. Not sure they will customize for fc cart and honestly I'm not sure I'm bothered. I'm seeking best sound, not looks
Ikeda arm has best looksI'm seeking best sound, not looks
at some point will likely have Joel Durand route cables through one of my Tosca's. he's local. the DaVa seems to work well on the it. the wires outside don't bother me.Is anyone dedicated to the Dava enough to have the cable routed in the arm.
Lusted after the Melco when it was first out in the early 80's - I was a poor student and the brand came and went before I could acquire one. A few used ones slipped by. I actually heard the Beveridge loudspeakers and the Melco table in a local dealer show room.. wow!3 x DaVa on Melco
I have my DaVa on the FR 66--- I have diverted my attention to the Etsuro Gold lately and I will fine tune and play the DaVa in the coming week.since ikeda is good it will be interesting to hear it with FR 66 and Glanz
I think you would have to give careful consideration to shielding with FC wires routed internally- And if they are shielded- then you have to worry about binding depending on horizontal bearing design. I "may" have Rick Mak of Analog Magik who is in our audio club try this on the FR64s I have---- if I find the DaVa worthy enough.Is anyone dedicated to the Dava enough to have the cable routed in the arm.
I think you would have to give careful consideration to shielding with FC wires routed internally- And if they are shielded- then you have to worry about binding depending on horizontal bearing design. I "may" have Rick Mak of Analog Magik who is in our audio club try this on the FR64s I have---- if I find the DaVa worthy enough.![]()
That's tough.How do you like your FRs compared to your Kuzma?
