I shipped a FR64S to Richard Mak and had it converted to 66, new Abec9 bearings and continuous wiring from cart clips to rca
It sounds very good with NOS Kiseki Purpleheart
Have you tried the Dava on this 66s
  • Love
Reactions: LanschePlasmaGuy
not yet
it´s not wired for DaVa fc dc
and when I alternate between the Soul in Harmony, The Ref in the Sonoro and the Kiseki in FR66, I´ve found a nice combo of readily mounted cart/arms/SUTs and cables that I rotate acc to music, recording etc
I rebuilt my riaa for 5 mm inputs by a switch
2 more are fixed onboard mc: DaVa mono and the original S&B TX103
I have my arms in Singapore for rewiring
I have waited 7 months as a project to get my table - in another month I am optimistic I can share with the world
I decided to go with Yamamoto titanium H6S headshell - you need to drill a little to make holes bigger but the titanium helps cool the dava vs wood and you can adjust azimuth so went with this. Arche seems to complex - need PHD - NASA experience
With regards to ordering a DAVA SOUL & DAVA MONO & DAVA TUBE PSU from Darius, I have tried the both service@cartridgeretip.com & Dava@dava-cartridges.com, but am unable to connect. How else can Darius or an associate be contacted to order these cartridges, is there a WHATSAPP available, I feel like that would be best as I communicate with everyone and their mother that way.
Thanks,
DC
+1-919-641-5483 (WhatsApp & cell)
lovevinyl1212@gmail.com
I am interested in this headshell, and thought the alignment problem (between two holes) could be solved by loosen this screw and move the headshell body slightly away from the connector. The ClearAudio headshell also uses this method to adjust alignment. Can this be done with this headshell?
Thanks !
Thanks,
DC
I have always had success with reaching Darius at:
dariusvaliunas@gmail.com
I'm expecting my Soul to arrive sometime in May which I ordered in December of last year.
I did get direct wiring but have both Yamamoto HA-1 and Harmony magnesium that fits
I ran the DaVa Soul at AXPONA on my SME Model 12 Mk2 with a Series V tonearm that SME was able to wire with 6-conductors to accommodate the field coil. I was beyond pleased with the results, and really made the new Treehaus LCR phono show what it was capable of. You can see the FC wires from the bottom: SME made a nice aluminum piece with a standard DC plug to attach your power supply of choice. To the casual observer you wouldn't realize it was a customized build.
A bit OT, but I like the casing of your phono preamp!
