Yesterday I removed the light weight standard head shell screws and mounted the much heavier Soundsmith ones in order to increase the effective mass on the all ready modified Reed 2B. Had to cut the length quite some since my mono can’t take longer screws than 4 mm.
Am I doing much? Isn’t that part of the hobby?Why are you doing so much with a Reed arm, instead of simply using the cart on another arm like FR64s, 3012r, etc
Don’t know. Had to go to Bauhaus Vestby for some materials for another project.And?
As Leif says, the 2B was part of a trade in and Reed modified it with brass insert in the arm wand and power supply wires integrated. However, the head shell is on the light side and heavier screws were added.
My 64s will fit my FC-A1 and the 3012-R my Vdh Grand Cru.
I was never impressed by Reed 3p and the 5T seems ok but overpriced. Not sure how the 2n modified with a brass insert compares to your FR.
Since you have headshell arms, is it easy to swap mono and stereo headshells?
Richard just finished my FR64S-full cleaning and restoration, conversion to 66, bearing, silver wire, extra counterweights, the whole package-it’s about $3,000. His work is simply outstanding.I´m in contact with him now
did you do the whole package, continuous wiring, Kondo silver, new bearings etc?
The arm is amazing with SPU 95 Anniversary on Melco TT
Thanks! Thinking of doing the full conversation/restoration on my 64s, so appreciate the information.Richard just finished my FR64S-full cleaning and restoration, conversion to 66, bearing, silver wire, extra counterweights, the whole package-it’s about $3,000. His work is simply outstanding.
Better resolution, goes deeper in LFHow does it compare to the 3012r
I wonder how that SS plinth compares to the original cast iron?very cool
I have Melco 3560 too, but with 65kg ss 4tower plinth
Got itthe Melco is graphite iron
the ss has superior bass and absolutely no reconnanses
can not detect any sound when listening through mechanical stetoscope
I have received my DaVa Soul for a couple of days and loving it so far. While waiting for my Reed with internal wiring I am using tapes lol, no problem so far. The rubber bands that came with the Soul is a little too small for the Safir 9.
