dCS Bartok versus MBS Discrete DACs?
Alpha121
64
42
98
Guys,
I am upgrading across my system, and seeking to replace the Schiit Yiggy (which is great and has served me well) with a more advanced DAC. I have come to focus on two well regarded brands and models: The dCS Bartok (non-Apex) and the MBS Discrete. Both are at the entry point of their respective well-regarded product lines. I plan to keep my pre-amp, as I am highly satisfied with it. Amps will probably change.
My questions are these for those who have such experience:
1) How does the presentation differ in the dCS versus MSB, in terms of the way such characteristics are viewed? Separation, sound field, etc?
2) How do the other sound qualities we are commonly concerned with, manifest themselves, such as blackness, smoothness, organic nature, brittleness, dryness, whatever... in each unit?
3) Lastly, how does the technological approach taken by each company, and used up the product line, account for what is heard?
I exclusively stream Qobuz for my listening at whatever highest resolution is available.
Thank you so much for your kind observations. I only ask that this thread stay focused on the questions posed and the dCS and MSB units indicated in this topic, and not devolve into a recitation of recommendations for other DACs:).
Thank you.
Had both. MSB will be smoother and more organic sounding. dCS more transparent and detailed.
If you are planning to still use the DCS Network Bridge, then you won't be getting the best out of the MSB. The best interface, which I have heard on a range of systems, if via USB into the Pro ISL interface.
The workaround is to use digital AES/EBU into the Discrete and then connect the Word Clock output from the Discrete to the DCS Network Bridge. This way you are guaranteed the clock in the DAC is the master clock, giving optimal performance.
That said, Pro ISL interface is still better because you get total isolation from transport to DAC. Just IMHO.
That said, Pro ISL interface is still better, IMHO.
Thanks very much, Shawn. And yes, all else equal I would keep the DCS Network Bridge.
I was totally unaware of this approach, so thank you. I will look further.
I would also add that Yggy sounds much closer to MSB than dCS. So if you’ve already tried a bunch of DAC chip DACs around Yggy’s price range and still prefer Yggy, you’ll most likely prefer MSB over dCS.
Thank you.
I have an original Yggy with the revised analog section. I like the presentation a lot.
In your experience, do you think there is significant improvement to be had going to the MSB Discrete?
Thank you.
The original Yggy uses a 16-bit R2R DAC and if you know what to listen for, you'll notice that it has poor small signal linearity so microdetails are lost and the soundstage depth is shortened. By comparison, the MSB has superior digital filtering and much improved small signal linearity.
The problem is that not everyone can hear or care about digital filtering. A friend just added a Digital Director to his MSB Premier DAC and at first, he was convinced there was no sonic difference. After I told him what to listen for, he recognizes the sonic difference quite easily but felt that for the sonic improvements he got, he didn't think it was worth it.
And similarly, the improvements in small signal linearity may be worth a lot to you and may be worth very little to you.
Personally, I think MSB Discrete is a significant improvement over the original Yggy. But I know some people who would argue the improvements are there but they're not significant. And I also know people who would feel that while the improvements are significant, they don't think it's worth the cost.
Part of the problem is that products like MSB & dCS are like luxury cars. A Honda Civic and a Tesla/BMW take you to where you need to go, particularly in city driving. Is the upgrade from luxury cars worth it? Hard to say since it's so individual dependent. What is for sure is that you're getting diminishing gains from your dollars.
I've had both at different times. I definitely prefer the MSB, which is fairly warm, thick, and analog tone. Maybe a little slow, but big, rich sounding stage.
The Bartok is very digital, has sharp edges, less substance, but very precise, detailed, and does DSD really well. A bit more temperamental with cables. I don't like the network input, and it seemed best from AES.
Neither are the most punchy or dynamic that I've heard.
In that range, my own tastes would be an EMM MA3i, or similar Playback Designs, which are faster and more flowing than the Discrete, and less digital than the Bartok.
But between the two, the Discrete, esp if you can get the Pro USB interface and the biggest power supplies you can afford. It's just more rich and musical, if a bit mellow.
Ian,
It's funny that you would mention the EMM MA3i, as that is the third choice I was considering.
I considered these two first, as the reviews I have read on the MA3 indicated "Its overall sonic persona leaned more towards lush and fluid than vivid and detailed...".
You seem to think that the MA3 is the best tradeoff?
Ian,
I would position it between the other two in character, and it happens to be one that I like. All different DAC circuits: R2R, 5 bit Ring DAC, 1 bit DSD. I like how smooth, fluid and natural the DSD DACs sound, but I'd say they are less warm and "gooey" than MSB, and softer edges than MSB or DCS. Probably as detailed as the other two, but if you have the Premiere Power supply that really changes the game for the Discrete in most ways.
I think the MA3i should sound more present and vivid, but I think the drawback I found with last gen Meitner/EMM was the sound being a bit conservative and without so much color richness.
And then there are the chip ones like Weiss and Bricasti than punch pretty hard and are more conventional digital designs.
I would argue the dCS is very organic now due to the Apex hardware upgrade.
Ideally you want to listen carefully to both and see which suits you best.
I would argue, as I often do, that diminishing returns are a crutch and the extra 10% or so you get in some metrics actually translates significant and commensurate additional musical engagement.
Again, the Bartok is not an edgy digital sound pos-Apex. The weakness of the Bartok was in large part due to the output stage in which Apex offered a ground up redo.
@Alpha121
I owned the Discrete and currently own the Premier. My transport is the Antipodes CX.
For what it's worth. I have demoed the Meitner MA3 and it was really the softest sounding DAC i have heard thus far. I have heard both the Holo May and Spring 3; many called them on the softer sounding side of R2R DACs but in the setup I heard, the Meitner was way more relaxed and softer sounding compared to the Holos and the MSBs. For some reason, I prefer the R2R sound more than Delta Sigma.
I went with MSB after extended demo sessions. They had that punchy AND deep bass extension coupled with the toe tapping factor that really pulled me in.
I would agree and add to what @ecwl highlighted. I have done several low cost tweaks (umbilical upgrades, etc) that really brought the black backgrounds, glare reduction and the imaging, separation and micro details to another level. All this without making hefty investments like getting the Digital Director (though you would need a really good transport to begin with) or the MSB Premier Powerbase.
I stuck with my dual Discrete power supplies after hearing the Powerbase brought only slight incremental improvements to my system. The most obvious and audible for me was with acoustic tracks - with the powerbase the guitar strums were huge and had a really nice golden afterglow effect.
Again, just MHO and YMMV. You will either love or hate MSB's modular approach. If you are a tweaker, like me, the modular design of the MSB can really be a nice to have.
Reactions: Ian B
@Alpha121
It is hard to put some of this stuff into words, because descriptors can sound contradictory. For instance MSB is warmer than Meitner, but has digital sharp edges (DCS moreso), where Meitner is smoother/softer. So it's like one gives you more analog tone, but slightly more digital waveform, and the other has a more analog or smoothed waveform, but less warm tone.
I've also observed with the Discrete I'd hear a guitar strum as a single musical event, but with Meitner/EMM I would hear each string as separate in time (with a little rounding of the attack). With the older Bartok I had, DCS also had some of that time separation, but not as defined, and with sharper edges. For some, that means MSB vibes and gels really well, feels propulsive, but relaxed. But I tend to prefer more fluidity, time resolution, and smoother corners. Both are great, so it's just taste.
I think all bets are off with the new MA3i, though because the new power supply, clock, and analog circuit. Seems to be described as richer, tighter, and lower noise than the MA3.
Reactions: shawnf
This is a bold statement with questionable technical claims which I will get to eventually. I will be a dissenting voice here; let me first start with listening impressions. I use my Yggy for CD playback, and I have heard diverse MSB DACs (Premier and Reference) in various settings elsewhere, on streaming or playing of local files.
I had first an original Yggy, then the second version of it (Analog 2) and now, since about 2 years, the Yggy LIM (Less is More), which is considerably better to my ears. Yet with any Yggy, soundstage had always been great in my room. Audiophiles who visited over the years, including vinyl fans, have consistently admired my soundstage and its depth. Before I had Yggys I had a Berkeley Alpha 2 DAC, and the Yggy does not shorten soundstage depth either in my room relative to that DAC (which as a delta sigma measures better in some respects).
This last summer a gear designer visited my room and he commented that he had never heard such spatiality from digital before (and he commented positively on reproduction of hall ambience as well, see below). So I seem to have something going on here, in my particular room. I also have the speaker drivers out from the front wall by more than 7 feet, which helps.
The Yggy is also very capable of portraying hall ambience, another low level signal for which you need great linearity. Recently I did actually think that the portrayal of hall ambience might be a bit exaggerated, with on some recordings a sonic glow illuminating the instruments from within further back on the stage in their interaction with the reverberant hall. Yet when last season I visited again Boston Symphony Hall for a number of concerts I was struck by hearing that there was that same kind of effect. I concluded that the Yggy, and my system, are astonishingly faithful in their capability of portraying hall ambience, something that, frankly, I had not expected to this extent.
As for MSB, I have not been struck by a significantly higher capability to extract finer detail from instrumental timbres, even though I have to admit I have never heard a comparison in my own system and room.I did hear better performance here and there elsewhere, but then my system caught up, recently with new speakers, and I heard the same level of inner detail with the Yggy (e.g., on the subtle fine structure of the sound of massed orchestral strings).
The only time I heard, in another system, a direct comparison between an Yggy (Analog 2 version) and an MSB (Reference DAC) it was clear that on complex orchestral music the MSB could unravel the different instruments and instrumental groups slightly better. Yet that shows a weakness of the Yggy Analog 2 (and the original version). As I was able to establish with a comparison in my own system, the LIM version that I now have also separates instruments better than the Analog 2 and presumably is more like MSB in that respect. It is super clean where the Analog 2 congeals and even slightly distorts.
Whenever I heard an MSB DAC it was not in a setting with great soundstage depth, so I have no direct comparison between MSB and Yggy LIM on that front. I only know that in my system and room I have significantly better soundstage depth than in the settings where I heard an MSB.
There was only one exception where an MSB came at least relatively close on spatial depth in another room. The owner had found by measurement that the powerbase of his Reference DAC emitted a strong electromagnetic field. He then physically separated the DAC from the powerbase instead of stacking them (MSB themselves don't indicate that stacking is bad), and the soundstage went from relatively flat to much deeper, with better hall ambience as well. Apparently the field emitted from the powerbase had messed with low level signal processing from the DAC.
All in all, so far I have heard nothing from an MSB performance that would entice me to give it a try in my own system and room, also given the to me prohibitive cost. I don't see why I should spend so much money on a DAC if the benefits are not glaringly obvious to me. I do spend money where it counts. The $ 2K Yggy feeds into a $ 15K preamp, and sonically it makes complete sense. The Yggy is that good.
I do have to say that I am pampering my Yggy quite a bit. I have it on a great power cord (ZenWave PL-11) that costs more than half of the DAC itself and makes a good difference. The AES/EBU cable from MIT that connects the Mutec reclocker between CD transport and DAC to the DAC is almost as expensive as the DAC itself. It too makes a difference. As for the reclocker itself: Like so many DAC manufacturers, Schiit claims that the internal clock very well corrects any incoming jitter. That is not true. The less jitter your source has and/or the more you correct incoming jitter via reclocking, the better the DAC performs. The reclocker also renders reproduction of hall ambience more robust and convincing than when it is omitted from the chain. For my playback chain, see my signature.
As for digital noise from computer audio (which I don't use), the Yggy is sensitive as well. Also, the original Yggy had a so-called USB 3 input which, as later reported, clearly was a weak link (my first Yggy in 2017 already had a USB 5 input, current version is USB Unison). All early Yggy reviews and comparisons that used the USB 3 input can be dismissed as irrelevant, that input was no good (unlike the AES/EBU input, for example).
Now to the technical points:
The statement that the original Yggy uses a 16-bit R2R DAC is not true. It's a 20-bit R2R DAC chip. However, the LIM version that I have does use a 16-bit chip (with use of dither). It still sounds better. Mike Moffat specifically looks for high linearity of DAC chips, which is one reason he does not use regular audio chips but industrial precision chips. The ones he uses have very good INL and DNL numbers; he says those of typical audio R2R DAC chips are so bad that the manufacturer does not list them (I have checked a few classic audio R2R DAC chips for that; the data sheets indeed mention nothing on those numbers). As for the MSB digital filtering being superior, that may be debatable. The Yggy does *not* use off the shelf filtering either, but a proprietary algorithm that Moffat developed in collaboration with a math professor who solved a "divide by zero" problem posed by wanting to optimize for both timing and frequency response (he describes it in the Schiit book from a few years back). The filtering algorithm runs on SHARC processors.
So yeah, my experiences of low-level linearity with the Yggy are different from yours, but it may well be that I run mine under more optimal conditions than what you have heard. And it's a different version, too (the DAC card can be changed from the original for $ 550).
Rather than changing the DAC, I am much more interested in improving the signal upstream further with an external 10 MHz clock for the Mutec reclocker.
Only then might I think about another DAC. Yet rather than MSB I would be thinking about trying the new MIB (More is Better) version of the Yggy, which is supposed to be yet better than the LIM version (I could also upgrade for a lower price via upgrade of the DAC card). Yet this is low priority for me; first some acoustic changes for my room and the external clock.
One consideration is whether the unit can be (reasonably) upgraded in the future. I do not know about MSB in this regard, but dCS is designed to be upgradable and has proven to be so when they released the APEX upgrade. I recently heard a presentation by their sales rep (from the UK) and this feature was emphasized.
PS: Definitely get the APEX upgrade if the unit you are considering has not already been upgraded.
Reactions: Lee
@Alpha121
Thanks, Ian.
The softness of the MA3 is a consistent comment across reviewers and users. It's the main reason that I have been focusing on the dCS and MSB.
I suppose the question is how does the new MA3i sound, and have all the changes addressed this? I have not heard of anyone's feedback on it. It's not clear that a MA3 can be ugraded but I have asked Meitner.
I really appreciate all the highly expert insights here from you, Al, Shawn, Lee, et al. Your comments are highly valuable are worth more than a dozen reviewers!
A Bartok Apex is out of budget unfortunately, so I will have to focus on the Meitner and the MSB.
Reactions: shawnf
Another DAC worth checking out is the TotalDAC. It has an uncanilly full boded presentation.
I had a Discrete at my house. I was comparing it to my Mojo Audio. A older version of the Mojo than the one I have now. For 3 days I was consternated at what I was hearing. I was confused. On the 3rd day it hit me. My Expectation Bias was saying the Discrete was better. It's MSB, RIGHT. When I finally realized the Mojo Audio was better, it all snapped into focus. If you like the MSB sound, get a Mojo Audio as it's a better DAC and half the price.
30 day trial period. Should be for the MSB too. Nothing to loose.
