Hi all. I want to ask if someone can help me about the compatibility and improvement that a Denafrips DDC Gaia, which I have been very interested in, can do with a DAC, Wyred 4 Sound DAC-2se and I would like to know the possibilities of improvement that it can offer me. Regardless of my next step being the acquisition of TERMINATOR Plus, which I love, I cannot afford it right now. With an effort now I could assume the purchase of the Gaia, provided someone can inform me about the suitability of my Dac with the DDC Gaia through the I2S format, because I think that would be the best connection. For better information I will tell you that I listen to the music through a Macmini (adapted with Uptone) and I also have Iso Regen through USB, which is how I normally use it, all through the Audirvana interface. The idea would be to bring Gaia via USB and then with I2S to Dac. This I know that with TP would be a good improvement, it is also in my case. Thank you
Hi Nanobenito,
Think nobody cannot advise you for sure of the possible and level of improvement in your use case by adding the gaia ddc for mentioned usb source to i2s input of your dac. Our equipment simply differs too much to advise ....
What I can share is that in MY system for the allo usb bridge signature, there is clearly an improvement in sound quality but not for the Antipodes EX. I believe that if the source is already of a certain level, you will not hear improvement but may even be worse sounding.
Note also that this is with TP+ that has the advantage of synced clock which you will not have with your dac and if your dac is in lower level than TP+, I will not be surprised if you do not hear any improvement.
The gaia with clock inputs is designed by Denafrips to match the TP+ with clock outputs and expectedly tuned together good best sound .. other dac and even their own dac e.g. standard Terminator etc. that is a step down and without synced clock cannot be expected to achieve the same level of improvement in sound quality that I am hearing from my allo usb bridge signature going via i2s from gaia to TP+ with synced clock to ocxo clock.
Cheers.
Richard
