If it had sufficient bass they wouldn't have released a sub for it.From.this picture you can see what i mean , if a speaker has sufficient bass out put it can be placed free in the room .
If it needs the walls its already a compromise
Matt
Matt
Matt
Almost no speaker, "full range" (lol) or not, has sufficient bass not to need a sub. Exceptions among some really large speakers allowed.
There are speakers designed to be placed in close proximity, say about 10 cm to the wall. i would not call these a compromise.If it needs the walls its already a compromise
Yes, I think most serious audio companies understand the need for subwoofers for realism: ,Avantgarde Trio and MBL Extreme, for example, come with very tall subwoofer towers as part of the package. As do Mike L's speakers.
Wilson and Magico sell sub woofers as add ons.
What exceptions are you thinking of, out of curiousity?
What, no love for my Kef Metas? ;-)I spent this past weekend at the Lone Star Audiofest. This is a very laid back, small show where it is really more about being social with friends you have not seen in a year than it is finding the best new thing. There were two standout rooms. One was the Infigo room and the other was the Rosso Fiorintino room. Both rooms had Rosso speakers. And although I have always liked the sound of Rosso Fiorintino in general what these two systems showed off was what can be achieved in a hotel room.
The sound was really fantastic. Especailly in the room with the Certaldo speakers. There was zero bass boom. The sound was clear and extended in both directions. Very good imaging and soundstage. Vocals sounded inviting and I could connect with the singer. Skip played some EDM by infected Mushroom at pretty high levels that could pound your chest and really pressurize the room. It was very clear and clean sounding -- never sounded out of control or muddy or boomy. I was in that room quite a bit and heard the amazement of several visitors who could not believe how good and how much bass was coming out of those speakers.
Why was this room so special? Well, I will give some credit to the great sound that Rosso Fiorintino and Norma electronics make in general. But without attention to a detailed setup the sound would have been just like all of the other hotel rooms in this show and the other shows like AXPONA. Most of the bad sound that we are having to tolerate at the shows comes down to one of two things. Either the dealer is too lazy to be bothered with spending the time to get things right or they lack the skill to get it right. It is possible to do as Skip just illustrated. They need to stop blaming the room and step up. If I was in the market for speakers at this show the Certaldo would have shot to the top of my list based on the others I heard there. There was one exhibitor there with a $25K two way that didn't even come close to the Certaldo sound at $10k.
The KEF Metas did sound good. But that room was always packed and I never really got a chance to sit in the sweet spot and listen.What, no love for my Kef Metas? ;-)
The Rosso Fiorentino / Infigo Audio room was really quite special. I went there several times and spent some time with the Infigo designer sharing a beer back at my room. Some innovative tech in that gear IMO.
Completely joking, it was a fun little show with some better than typical equipment and systems than previously.The KEF Metas did sound good. But that room was always packed and I never really got a chance to sit in the sweet spot and listen.
Understood. Yes, LSAF is fun every year. Your room was a blast. Free Beer! Thanks for setting it up.Completely joking, it was a fun little show with some better than typical equipment and systems than previously.
It’s also tied closely to the Brinell hardness profile of the spikes. Sadly, the only reliable proof strategy is destructive.Good job Tom. 1/16" is just over 1.5mm. You are getting close. The real magic happens when the adjustments are under 1mm. And spike adjustments are in the 1/64th or less of a turn. Keep going.
I'm curious if anyone ran measurements with such minute changes and if they're identifiable.Good job Tom. 1/16" is just over 1.5mm. You are getting close. The real magic happens when the adjustments are under 1mm. And spike adjustments are in the 1/64th or less of a turn. Keep going.
Hey bud! I'll get there. The current room is on carpet over a joist suspended floor, the spikes are dulled at the points, so this is as close as I can get right now.Good job Tom. 1/16" is just over 1.5mm. You are getting close. The real magic happens when the adjustments are under 1mm. And spike adjustments are in the 1/64th or less of a turn. Keep going.
NIce , just a suggestion if I may. Keep up the exacting work. I am not a spike fan and would suggest you find some adjustable footers for your speakers ( not suggesting brand specific) but on a floor they work great and I believe will give you a better result than spikes, and depending on what you choose much easier adjustability.Hey bud! I'll get there. The current room is on carpet over a joist suspended floor, the spikes are dulled at the points, so this is as close as I can get right now.
The new room will be on a concrete slab and the spikes will be ultra sharp (sharp enough to prick and draw blood easily) and also on pucks. No carpet. Should make it much easier to get tighter tolerances. Here's what I use to dial everything in;
It took me about 6 hours of getting the speakers exactly where they need to be, adjust toe in for a perfect blend of tonal balance, a wide sound stage width - without losing the phantom center image(s). I'll keep checking every three or so hours to see if anything has shifted (especially after giving the rig a good workout with demanding loads) but after all that work? It was SO worth it to the end result as to what hits my ears now.
That Digi-Pas really helps out with 6 and a half foot tall speakers. No more up and down, up and down. Just set the unit on top of the speaker, set my phone down on the floor and dial in. Then check all of the other parameters to make sure they are still within tolerance. One adjustment can knock out one or more parameters, so this has to be done again and again until all of the parameters are correct.
But when you are done? Bliss. Pure, unadulterated musical bliss.
Tom
