Yes indeed! This is a more correct explanation.No, it is the fault of that specific example...
Charles
Really? Its well-known that the prodigious 2nd harmonic (which all SETs have unless they use feedback, which most don't) imparts 'warmth'; a euphonic coloration. That fact has been known since the 1930s and isn't controversial.No, it is the fault of that specific example...
+1 tubes for life… or is it just being SET for life…What ever the case may be with tubes and particularly SET and distortion. They consistently provide the most natural sound I have heard from recordings. The end result is all I care about. The debates /argument can continue for eternity.
Charles
No- we can't do that. THD was all there was in the old days, back when tubes were King.I think we should acknowledge specs were designed to favor solid state. THD eg
I guess the student has not surpassed the teacher.No- we can't do that. THD was all there was in the old days, back when tubes were King.
Nowadays we can display the distortion spectra- and actually see why a tube amp sounds the way it does or why a solid state amp sounds as it does. This should tell you something: If you build a solid state amp that has the same distortion spectra as a tube amp, it will sound like one too.
Audiophiles, IMO have grown too used to thinking the spec sheet tells you nothing about how it sounds, because for most of the last 100 years that was true. That started to change in the 1990s and today (if all the measurements are actually made) you can tell how the amp will sound from the measurements if you understand their meaning. IOW there is a very direct link now between what we can hear and what we can measure that didn't used to exist.
From the Mola Mola website regarding their Kaluga amplifiers: "Unprecedented low distortion, noise and output impedance combine into what scores of enthusiastic users unanimously describe as “no sonic signature at all”."No- we can't do that. THD was all there was in the old days, back when tubes were King.
As long as distortion exists, no.Is "no sonic signature" possible?
Not completely but that is part of the SET successis it possible for distortion to exist and be beyond our ability to perceive it or to recognize it as such?
Are you saying that a valued attribute of SET amplification is that it's hard to hear its distortion - or that the distortion simply sounds musical?Not completely but that is part of the SET success
That is what some say. The numbers guys will tell you -70dB is fine. IMO/IME the distortion needs to be less than -105dB (0.0005%). This is simply because when you have distortion that low, its likely all higher ordered harmonics. The ear has over a 120dB range and uses higher ordered harmonics to sense how loud a sound is- so you can see that -75dB isn't going to work... or even -100dB...is it possible for distortion to exist and be beyond our ability to perceive it or to recognize it as such?
SETs work because the 2nd and 3rd harmonic are so prodigious that they mask the higher orders. So the amp sounds rich and musical, since those harmonics are musically pleasing with the fundamental tone.Are you saying that a valued attribute of SET amplification is that it's hard to hear its distortion - or that the distortion simply sounds musical?
The problem of course is that distortion obscures detail. For that reason, to get the most out of an SET the speaker needs to be so efficient that the amp is never run past 20-25% of full power (-6dB of clipping).
Push-Pull amps, if combined with single-ended circuitry, like the Dynaco ST70, will tend to exhibit a bit of a 5th, which IMO is why the SET guys tend to not like P-P amps. But if you run the PP amp fully balanced the 5th is less prominent and so the amp can be smoother than an SET, even though the 2nd might be lacking. For this reason P-P amps have a greater usable amount of power, up to at least 90% of full power.
But you can see this all about sculpting the distortion spectra. The best designers seem to understand this; Nelson Pass or John Curl for example.
That it is hard to hear it’s distortion due to the specifics of how human hearing works. Your ear/brain mechanism generates its own distortion, which results in masking if the pattern generated is similar to the ears own pattern. The closer the match the better the distortion “hides”. The pattern itself matters because hearing is exceedingly complicated interplay between input signal of ear vibrations and mental processing.Are you saying that a valued attribute of SET amplification is that it's hard to hear its distortion - or that the distortion simply sounds musical?
A simpler way of putting that is the 2nd harmonic is so close to the fundamental- its only an octave away so innocuous. Similarly, the 3rd harmonic is an octave and a half and also always at a much lower level than the 2nd (if the 2nd isn't present, still at that lower level). So not just masking- but musically Ok (if you have a keyboard instrument around this is easy to demo).ZB
I think the thing with SET amps is they are more psychoacoustically correct vs others in terms of distortion spectra, no zero-crossing issues, no issues with mismatched halves of a balanced amp, etc. so when properly implemented the result sounds very good, it's closer to what the brain expects to hear and in the best cases it's not identifiable as a tube amp at all.
