Tim,
I guess my point is more directed towards the DBT-type sessions where there is usually a null result returned i.e no difference found.
Why is it so hard to accept the simple answer?? That they simply COULD sound the same?? There are the hardcore subjectivists that calim EVERYTHING affects the sound, that it is impossible that some things could be indistinguishable, but do all think that?? There are the hardcore objectivists that claim 'nothing sounds different', but do ALL think that?
But I'm also asking why is blind so important? Is it just accepted wisdom or is there a scientific basis for this particular bias being singled out among the many?
Edit: here's an interesting question (maybe) Is there a statistically significant number of blind audiophiles who have cheaper audio equipment then sighted audiophiles i.e they just judge on the sound alone?
Serious, are we stuck on the defintion of blind here?? We can't be can we?
Anyway, I'm just surmising, not holding a hard line on this (although sometimes the discussion backs you into a corner where it seems like you now have to adopt a hard line), just throwing out some thoughts on a forum that others might think worth considering. Then again they might not be worth considering?
If we take blind, unsighted to mean no knowledge of which unit we are listening to then yes, I think it is no longer worth considering.
