Two channel is not in any way a compromise in regards to ___? I am not following you.
Tom
I was responding to Soundproof's assertion that two channel is a "joke".
Tom
I would be very interested in that topic and have some data to shareOdin and Mike L. - You guys are really in a different discussion here, aren't you? Maybe another thread that addresses the failings, real or perceived, of 2 channel audio?
You'll have to point out exactly where I have mentioned "multi-channel" in this thread, beyond where I asked you to clarify that point. You must have pulled that out of some preconceived notion as to what you thought I was writing.
Two channel stereo is a joke that relies on a phantom center illusion that not even cheap surround systems would accept - yet people are happy with imagining what's missing.
So to answer the question: No, we do not listen with our ears, but with our pre-programmed expectations.
As to my intentions, they are quite benign, though I do sense some mystifying push-back here. As well as the standard "if Soundproof listens in that way, then pity the fool."
Our sense of hearing is easily manipulated, and we do quite a bit of the manipulation ourselves.
The only thing I ever bought sight unseen was the Oppo DV-980H. No one I knew had one, but I felt comfortable enough with the reviews and the return policy of our local Canadian distributor to take a chance.
I am not supposed to write in green, or moderate threads, but IMHO it would be a nice thread if people posted their own experiences, not just vague insinuations about other audiophiles practices.
Ohlsson's made quite a few of the finest Motown-recordings ever made:
There was a thing at the AES called "When Vinyl Ruled' - this was incredible. I hope to heaven that they let them do it again but I can see how a lot of manufacturers would not let them do it again. They set up a state of the art 1962 control room and played back a bunch of old 3-track safety masters from that era. The sound destroyed everything at the show. I mean, it was a no-brainer better than anything we're doing now, it's sickening.
http://www.tapeop.com/articles/30/bob-olhsson/
The fact that we're satisfied with a phantom image doesn't mean it can't be improved. I have a center-image that has people comment it without fail - but I have also heard the 3-channel alternative, which makes what I have pale in comparison. Two-channel is an inferior compromise, imposed upon us by tech-limitations in the early 60s.
My experience on buying equipment without having heard it first in my system is mixed: I took the Lamm ML2 knowing alot about how complementary they would be to the Avantgardes- I suppose I could have returned them, and the line stage, if I didn't like them. Ditto on the Steelhead, which I kept for quite a while, but just recently sold. I did hear my actual turntable before it got delivered to my house, but frankly, apart from the fact that it seemed quiet and made the dealer's system sound good, that wasn't terribly informative.
And this is just one of legion examples of the same - it's quite OK, it's just the way we relate to stimuli, and it makes us individual. That's cool.
On the question whether one listens before one buys, I'm not sure anything short of an in-home trial, with an informed set-up, would be meaningful (assuming the equipment in question is already broken-in and if it's not, is the dealer going to expect/permit you to keep the equipment for a prolonged period with an absolute right to return it?) Short of that, listening to a piece of equipment in a dealership is not going to be very meaningful, aside from differences in room acoustics. Look at that other thread, where the guys went to Arizona to visit a dealer and couldn't listen to very expensive speakers under optimal conditions (and I'm not dumping on that dealer here, he was in the process of revamping his rooms); the related equipment is not the same as yours in many cases. And, how many times can you find a dealer who carries all the product lines that are relevant to your system? Not easy. My experience on buying equipment without having heard it first in my system is mixed: I took the Lamm ML2 knowing alot about how complementary they would be to the Avantgardes- I suppose I could have returned them, and the line stage, if I didn't like them. Ditto on the Steelhead, which I kept for quite a while, but just recently sold. I did hear my actual turntable before it got delivered to my house, but frankly, apart from the fact that it seemed quiet and made the dealer's system sound good, that wasn't terribly informative.
...Who here buys or has bought gear without first hearing it in their system....and why?
Results?
The MOST artificial sound I have ever heard is high end multi channel.
Mono to be is utterly a joke. Baby boomers who grew up on early mono rock n roll records still cling to it.
Two channel is not in any way a compromise. There seems to be this myth that we process sound in some sort of 360 degree manner.
Hello Andre
Maybe you should try low end multichannel instead
A myth?? Your kidding right. You live in a world that doesn't envelop you with sounds coming from 360 degrees in all three axes?? I will remember that the next time I am in the woods and hear a cardinal to the right a chipmunk in the brush behind me and low and the wind over my head in the trees. If you don't see that as any and all directions I don't know what to think.
Rob![]()
Or maybe you can explain it a bit better for us Myles
Oh yeah baby, information density. Another interesting term.
I take that as in regards to tape:
--run the vu meters above 0 to ensure we get an aural exciter effect on the peaks
--since tape is log and not linear we get a nice compressive effect across the band
--run pre-emphasis to overcome noise and and therefore specifcally compress the highs then we get a silky playback
(comments above are from research on the web some time ago)
Are these the things we are calling information density?
I am allright with it, just wondering if thats what you mean.
Tom
No I am not kidding. You THINK you are hearing something behind you but you are hearing it right or left and your brain is helping you localize the sound. It is something we learn early on and is quite amazing.
