You should also ask Gian to take you to Pepe57 (Pietro's) place to listen to the Yamamuras, which has the Zyx Ultimate diamond (plus many other systems in house including Goldmund Apologue and Prologue).
I haven't forgotten but there are 8 of us who will be in Italy and only Marty and I want to visit you guys. I will let you know as there are logistics here that need to be rectified
I am thinking about doing a ML2.2/LL1.1 SIG combo. The only thing holding me back is not being sure on the heat output on those 6C33C tubes. I know that by nature they run just as hot as the hotest, but in all the reviews and posts pertaining to the Lamm mono's, I can't find any references. My room is 13x17x9 and although I have central air, it is too loud to run when I am listening. (Lotta good that is). What do you think about the heater influence in my relatively small room? TIA
I have set up the same combo along with an LP2 in a room even slightly smaller than yours and no heat issues and have 2 pairs of ML2s in our small showroom http://www.whatsbestforum.com/showt...digital-too-Listening-Room-2-Near-field-setup without any heat issues but A/C is running in summer in both installations. All I can say is that the ML2.2 generates very little heat and if you can stand the room without AC then turning on the ML2s won't make it any warmer.
Are you a Lamm dealer, or are you affiliated in some other way? What would be your recommendation for a 20-35k speaker...either in a horn or single driver? By chance have you heard any Teresonic speakers, or even caught wind of their performance?
We are the longest running Lamm dealer anywhere and the only electronics we sell since 1999. Sold & setup more Lamm ML2 systems than anyone else !
As far as horns go your best bet is vintage and we can discuss your options offline. I'm not familiar with the Teresonics but know the Lowther driver that they use and I'm not a fan. I can go over some other speakers with you offline too, this is Steve's thread and I don't to take a different direction.
