not sure I understand??
"Server" volume? Or do you mean Dac volume?
I use the Taiko Extreme and do not use any Roon gain. All gain is controlled through my Lamm Preamp
This is incorrect as said but the conception is correct. But if Steve’s using Roon it’s vol control has draw backs to use.
Ty for your reply STEVE. his server is an Amazing product that allows the max ability of a dac we use with it.I use the Taiko Extreme and do not use any Roon gain. All gain is controlled through my Lamm Preamp
Congrats Steve, welcome to Lampi Land , I use an ancient GG1 with 242s into my Koda pre and it works a treat. Now if I understand correctly you have the PAC with Vol control... not bypassed and then thru the Lamm , so passing the signal thru two volume controls , is that not detrimental ,even if it is helping you adjust the gain.As stated all gain is via my Lamm Preamp, not roon
So you recommend getting a Lampi with Vol control and feel it worthwhile even with what surely must be a loss in transparency of the signal , as it passes thru two Vol. controls.It’s not just about gain it’s about a correct tone. As I said in a phono pre to pre gain matters in correcting tone. If you took the time to observe and compare you would find the music flows closer to analog and still has plenty of dynamics like analog has.
i find -12 dB on the Lampi produces the most analogue soundIt’s not just about gain it’s about a correct tone. As I said in a phono pre to pre gain matters in correcting tone. If you took the time to observe and compare you would find the music flows closer to analog and still has plenty of dynamics like analog has.
I was initially going to buy the Pacific without the gain control for reasons exactly what you state however talking to the experts here, all stated that the volume control on the DAC can be used for tonality.So you recommend getting a Lampi with Vol control and feel it worthwhile even with what surely must be a loss in transparency of the signal , as it passes thru two Vol. controls.
Based on my replies to you, I hope you see that these are 2 separate issues. The preampsweetspot discussion would equally apply to 300B tubes too. if Roon volume set at 70% and preamp volume set at 60% for BOTH 242 and 300b in his setup, then to enjoy the same SQ Stve would likely have to adjust to -12db in one setup and -15db in the other, but always in a range to get that sound character. To sound more SS like he would put Pac volume up to -10 to 0 db and to sound tubey, he would dip blow say -18db.Long before Steve got a Lampizator I debated gain issues with him concerning the Lamm's.
But yes, it is a general statement valid to any swap. A large voltage signal implies a larger output current, that increases distortion in the output, most of the times independently of the volume position. This change can affect our immediate perception of loudness.
However, the right way to do it is to first set the upstream components and then find preamp sweetspot, bearing in mind this is all a range. The ear will make the final decisions.
Ty Steve for your honest observation on this matter. I have in the past thought like jazz head I’ve been there. Many said any loss or anything in the volume path must be avoided
When I had my msb stack I paid thousands to have a volume control. But my msb stack was not a typical vol pot it was a passive gain path until it hit 0 then became a gain stage. Honesty I did not use it until a bud explained why it should be better in a gain stage then passive. He was very correct. In a LAMPI dac the gain path starts at the digital board and this is where the vol pot is. Then it as it goes to the golden set tubes it gains more and the rich sound of set tubes. This is why a lowering does not loose sound with just 15 dB or so yes to go lower does effect things. Anyway we all should try and observe it’s the best way. This is also true of my two otari tape decks. The vol pots sit in the middle of two gain stages like LAMPI.
I am finding this to be my findings. My thoughts are above -10 db on the Lampi starts to sound very solid state
I have no idea what volume the Extreme is set at as I have never messe with it since Emile set it up. I'm a set it and forget it type guy
Micro, it is sad that you are so inexperienced a listener as to be misled by immediate perceptions of loudness or any other artefacts.
Did I understand correctly that the volume control of Steve's Pacific is purely digital and has no analogue switching or attenuation?
