I have one Anaconda PC and 3 Anaconda umbilicals
Steve,
Are you going to try the Shunyata Zitron Anacondas?
I should have been more specific - I was asking about the signal cables - ICs and speaker.
As I stated earlier my next project will be to switch to all Shunyatat PC (probably all Anaconda) and then to switch signal cable until ultimately I have an all Shunyata system
The common statement with all of us here is that not one of us could ever listen to our systems again without the Shunyata gear described
I know of it - for a long period I had the old Hydra8, Anacondas, Antares and Orion cables. Although I later moved to ICs and speaker cables having more resolution, there was something "right" on having all cables of the same family.
I agree completely. I always felt a system sounds better with a common cabling throughout. As far as speaker cables with more resolution I can't comment only because my present project will be to replace all of my existing PC with Shunyata. I can comment on the resolution I heard with my existing Shunyata PC's as to be far better than the Valhallas I replaced
How can you commit to all Shunyata Signal cables without hearing them
I am one who prefers to use a system based on the same cable. I buy into a system wide approach. What I don't know yet is whether all components will benefit most from Anaconda but at the very least I might use some Python PC's as well as signal cables but I do plan to use Anaconda speaker cables as well as for the interconnect from preamp to amp UNLESS of course Caelin releases yet a cable at CES that transcends the quality of Anaconda then all bets are off![]()
Steve, you may want to keep your Valhalla speaker and ic's while changing over to the Shunyata's. I think you may well find that the Shunyata Speaker cables and the ic's do NOT bring as much to the game as the power products. The Valhalla's are VERY hard to beat in the speaker and ic configuration, IMO. A step up from Valhalla would be to Valhalla 2 or of course, Odin![]()
Not sure that I agree Davey but stay tuned as I intend to explore the option.
Let me tell you, Alex knows his audio.
It is always wonderful to not only put a face to a name but to meet these people.
