![fromvinyltoplastic.com](https://i0.wp.com/fromvinyltoplastic.com/wp-content/uploads/2020/09/DS_EQ1_front-e1599173846288.jpg?fit=891%2C362&ssl=1)
EMM Labs DS-EQ1 Phono Pre-amp - From Vinyl To Plastic
EMM Labs DS-EQ1 Phono Pre-amp. The first independently and purpose designed phono amplifier for the DS Audio optical cartridge range.
![fromvinyltoplastic.com](https://i0.wp.com/fromvinyltoplastic.com/wp-content/uploads/2018/06/cropped-My-Logo.jpg?fit=32%2C32&ssl=1)
Even in Jonathan Valin’s review, he talked about many different positive attributes and mentioned at least 15 different positive traits but if you go back and read the review again, not once did he use the word musicality. For me, musicality is probably one of the most, if not THE most important attribute I must have in a piece of gear. If a piece of gear isn’t musical, it’s a deal breaker.
*I tend to not use the term "musicality" myself, as I find it to not have inherent and widely-agreed meaning -- but I think I know what you mean by the term. I think "musicality" is even a more difficult term to define than the term "natural."
Though strangely Tim it might just imply a more central and original meaning and purpose to this wonderful hobby if the systems we create can serve musicality and the core purpose of connecting us to music rather than rocking our faberge eggs off over the sounds and the other distractions that systems can present.If you map the absence of an adverb (or any other word) in a review to the presence or absence of some quality or characteristic of the review subject, you're on your own.
"Musicality" may be my least favorite word for audio or tied with the word "slam".
I take "musicality" to mean either a) "it sounds like music", or b) "I like it." Otherwise it is largely an uninformative word. Trying to define it seems a waste of time. There is no hidden meaning that unlocks a door to enlightenment. It does have a certain lilting quality when spoken which may be its primary attraction. It is a word whose users say "well I know what it means when I say it."
To just simply more easily hear that the structure and approach that Bruno Walter brings to Mahler’s Resurrection symphony is more taut and restrained than Kubelik’s.
Yes I have a DS Audio Grand Master cartridge purchased! I’m going to demo the EMM-Labs EQ1 with it, and will also have a DS-E1 in house at the same time for comparison. Likely install date in a few weeks. Will post impressions once installed.Has anyone purchased a DS Audio cartridge since we started this thread?
Excellent! Please keep us closely posted!Yes I have a DS Audio Grand Master cartridge purchased! I’m going to demo the EMM-Labs EQ1 with it, and will also have a DS-E1 in house at the same time for comparison. Likely install date in a few weeks. Will post impressions once installed.
Yes they were very clever, create a cartridge that requires it's own power supply. Incremental purchase from the beginning and more loyalty from the consumer over the long run.Hi Jeffrey_t
The DS Audio Grand Master optical cartridge retails for $15,000.00. The matching two chassis power supply/eq has a retail price of $45,000.00. Therefore the.total cartridge system sells for an eye watering price of $60,000.00!
DS Audio was very clever. They designed it so that any cartridge can be used with any power supply/eq. So, just as an example, you could buy the Grand Master cartridge at $15,000.00 and use it with one of their mid level power supply/eq’s to get started. My local dealer has on display a Grand Master cartridge with their $8500.00 power supply. Doing it this way would allow you to upgrade the power supply as funds become available.
Best regards
Scot
