Hi all,
I would just like to reply to my own(!!) post above where I mentioned the Entreq Garbo 4 isolation feet. Today I actually received a demo set to try, courtesy of the excellent Australia distributor of Entreq who has previously sold me my boxes, cables and K2 knobs.
I am afraid the news about how they perform is not good. I firstly tried them under my Rega CD player. There was no improvement in any aspect whatsoever to the sound, however the sound significantly degraded in two other aspects - there was a loss of air and the sound became more coarse. It was honestly like I had lost bit-depth - and using a very bad word-length reduction algorithm at that. Ironically, this sort of degradation is precisely the opposite effect to what I experienced when I got my Entreq boxes and cables, and then again when I upgraded to the K2 knobs.
I need to emphasise of course that this is just my own experience and other people's may be different. For what it is worth, the Rega had previously been sitting on stock feet using a HiFi Rack XS rack (installing that rack did change the sound of the system in a positive way, especially in terms of detail retrieval). I don't have any explanation as to the poor performance though one observation I made is that since the coupling faces of these feet are machined wood, if they are not absolutely perfectly flat to microscopic tolerances, this might cause issues, since there is no obvious "give" in the feet like there are with rubberised solutions, for example. Two of the feet were dead flat, one wasn't perfectly flat - not visibly I mean - much more subtle than that. It was just that it did not sit as surely on the rack surface under no weigh as the other two did. And the rack surface is perfect - tested with the edge of a metal ruler at all angles during installation. Mind you, once under the component, the third Garbo 4 footer felt like it was flat. But in any event, there is no "precision engineering" evident at least to the extent that you would see in something like the Stillpoints, A10-U8, etc. I suppose "rustic" is a term that kept coming into my mind time and time again when it came to the physical characteristics of these feet. In an endearing way of course
I also tried them under the Entreq boxes but could hear absolutely no difference in sound whatsoever versus the boxes sitting on their stock feet. So very disappointing and I have to emphasise, the first Entreq component I have auditioned in which I am disappointed. But I thought it important to add this post, not only because I mentioned them in the post above but also to perhaps encourage anyone interested to demo before buying, despite the much cheaper price compared to other footers mentioned here.
Entreq do make two much higher grades of feet, but both are outside of my price range and indeed are more expensive than the A10-U8 (at least if I were buying here in Australia).
