When you say do the amp, are you referring to ground the chassis, negative output terminals, or both?
I'm living in mainland China, and there is a distributor here my dealer is working with, but there are supply issues, so the only units I can get in the short term are:
Silver Tellus Infinity
Silver Minimus Infinity
Olympus package
Olympus Ten
If I want to get a smaller unit, such as the Mimimus infinity, and use that to ground the negative output terminals, and I like the effect, I can I add another grounding box to enhance the grounding effect?
There are a number of non Enteq grounding boxes available here, just not sure they are of the same caliber or quality as the Entreq. Prices are much better though, so they are tempting.
I sensed that you are not fully understood what Barry and I have said so I will try to summarized in point form that I think will help you to make your own decision. I through you are in the USA but anyway, I will use the price in the USA for illustration as I don't know the price in your area.
1. Grounding your power regenerator thru the chassis or using the ground cable with the special AC connector will provide a good improvement. Just that adding a expansive PowerUS should not be a urgent need.
2. If you like to try grounding the negative output terminals of your amp with a Minimus Infinity or Silver Minimus Infinity or Olympus Ten box, you need to get TWO of these, ONE for EACH channel's negative output terminal. You CANNOT connect both LEFT and RIGHT channel's negative to the same ground post of the above mentioned boxes.
Minimus Infinity is US$450, Silver Minimus Infinity is US$850, Olympus Ten is US$1440. Olympus Minimus is US$2580.
Tellus 2 Infinity which contain TWO Silver Minimus Infinity and one Olympus Ten is US$2500.
Poseidon which contain THREE Olympus Minimus is US$5150.
Olympus Ten is a much better box than the Silver Minimus Infinity.
3. Grounding your integrated amp using the chassis method or thru the signal's IN/OUT jack is DIFFERENT than what is done in #2 above. You can do both #2 and #3, or you can do either #2 or #3 but I believe doing #2 alone will have a larger impact than doing #3 alone.
4. Yes, you can daisy chain multiple ground boxes together but you will need a extra ground cable and an extra Everest knob if you choose to use the Everest option. I really don't know how much better with daisy chaining. 1.5x? 2x?
If you really like to upgrade after getting a small box, you should get a larger box that fit your need and budget then use the smaller box somewhere else. You will never have enough of these ground boxes.
Hope the above answer most of your questions.
