Ah, I did not see that image .
My question in the last post remains. Is that a standard retail cable or one that they custom built?
I think the OP's point, if inelegantly stated, is that Entreq is using an existing inexpensive product (which I am guessing they believe or tested to sound very good) and repackaged it, hiding its origin to be able to sell it at a much higher price point.
That does bring up an interesting question. If a company goes to China to a cable manufacturer and tries out a bunch of cables. They find one that sounds as good or better than much more expensive well regarded "audiophile" cables. They have the company logo put on the cable, maybe with a different color and sell it for many times the price that some other company charges for the same cable from the manufacturer. The company's intellectual contribution is that they determined this particular cable sounded much better than others with a similar price point. If they were a reviewer for a magazine, they would publish the result for readers to know about this "bargain." But they are a company, whose allegiance is to its shareholders, not the general public. Ethical or not?
I remember a few years ago that a pretty well known audiophile company was "caught" taking one of the well regarded Oppo players, changing the faceplate, etc. and reselling it under their name and model number for several times the Oppo price. If I have that story wrong, please correct me.
Larry
One US audio/video cable provider sells unbranded bulk cables. So that home theater installer companies can wire a home with what appears to be custom cable rather than the budget cable that it really is.If I were making an expensive cable, or ANY cable and there were text imprints on it "USB2.0 CABLE FULLY RATED 30V" as seen in the photo, I would make damn sure MY COMPANY NAME would also be printed ON the cable.
The cable is someone else's ordinary, inexpensive cable.
TBH the number of actual cable manufacturers in context of manufacturing looms is pretty small when looking at audio (and other sectors) companies, not saying this makes it all right but just the reality.
Cheers
Orb
yes most buy the wire...perhaps made to spec and either custom OEM the dielectric/outer casing, ect or do it themselves. I don't know of one well known hi end cable manufacturer that makes the wire. Maybe Siltech does, maybe not.
Yeah.
Siltech-Crystal Cable conductor/core is manufactured at an advanced specialist lab I think in Germany (definitely though somewhere in Europe) so could still be deemed as internally manufactured as no other use this process.
Others I know of include Yter,Supra,Nordost,Dynamique Audio.
Some of the other known brands probably do, great if anyone knows for sure (sadly I do not know myself).
But then this also depends upon the cable function, doubt many of these fully make their own usb cables as an example.
Cheers
Orb
I still argue no mfgr. draws their own wire. Very expensive equipment. Rather said cable company custom orders the raw wire to spec and does their own dialecteic/config in house for the major hi end brands. Think OEM custom wire for the raw wire, not available for the low volume consumer.
