Ian, did you feel that my AirTight Supreme had those qualities when you heard it in your system? Or the MSL Sig. Gold? The Opus 1 is supposed to have even more resolution, extension and speed, apparently. I have not heard it.
There are cheaper carts which might go better, if money is a consideration. Multiple carts at this level are not for sonics, they are for those who don't need to save and want to play. Of course, to buy a cheaper cart when one has upgraded his speakers does not make optical sense
I think buying used cart from someone you can trust is a way to go. For example, the vdH that MikeL put on sale. Reasonable price and no need to do a long burn in. But you have to make sure Mike is not so clumsy .
My friend has CH L1,P1,a1 mono and Wilson Alexandria 2 and Atlas
Wilson has always too full midbass
And Atlas is very good in his system
He found better in P1 in mm/mc input
With 600 ohms
I use Atlas sl in current with 60 dB gain
If in your system midbass is full Atlas can be very good
If is neutral could be Opus is little better,little more natural
I've never cared about "optical sense" unless it is about the aesthetics in a formal living room with things like speakers, room treatment, or cables all over the place. If you are referring to prices and perceptions, sound has always been more important to me that what something costs or what others think. I have not bought a brand new cartridge in fifteen years, only gently used from good friends at heavy discounts. No issues there.
It won't of course. But it will answer the question of "would I have liked the Etna SL?" which is something I've been wondering but didn't have enough confidence. Even if I love it, I will be able to get a feel for what the Atlas sounds like since I've read a lot of comparisons. And, I can try and compare to Peter's two cartridges (even though I'd have to go by a memory that is already fading). I can also compare to my Zyx and Ortofon A95 (both of which I know very well).
It also provides me with another data point and helps slow down my decision making (I've been wanting a new cartridge so badly that I'm not even listening to analog at the moment).
I've been told that a cartridge I should consider is the Transfiguration Proteus D ($10.5k). Too many choices!
With 600 ohms
I think he meant that if you buy more expensive speakers then you have to buy more expensive other components to keep the upgrade going or you would not follow the typical high-end path but that was just a guess. Perhaps he will clarify.
It depends a lot on exchange policy of the manufacturer. Van den Hul cartridges are always an excellent acquisition - you can get them inspected, serviced or refurbished for a small fraction of new cost in a fast time. Some manufacturers will ask almost full price for a replacement or take an extremely long time to service cartridges.
Although the stylus can be inspected to check how long the stylus has been used and the expected usable time, it is not an easy job.
Ian, you can probably guess what I am about to say, but if you are going to spend that kinda money, maybe you owe it to yourself to listen to the Atlas SL at Myles's place...
Not sure I can guess, Tasos - or did you just say it? I didn't know Myles had the Atlas SL. Good to know.
I have the Etna SL on my table now. Brand spanking new so it needs break-in and I'm sure I don't have the arm height nailed yet. I'm on my 4th side now. This is nothing like my Zyx; I don't hear any midrange bloom (at least not yet). Much more like my A95 except much, much better.
Sorry, I thought you had read his review, and you know how much I glow about his system... Anyway, if folks are saying the Atlas is superior to the Etna, so much more the reason to audition it. I also kinda guessed you'd think the Etna would be better than the A95. Let us know how the audition progresses...
The Etna is better than the a95. The atlas is better than the Etna. The Opus is better than the atlas. The Miyajima zero mono on original mono classical will be better than the Opus on stereo LPs in many cases.
Not sure any of those generalizations are necessarily correct. It all depends and we are talking different flavors...what makes a cart better than another ? Pretty subjective if you ask me...when we are talking near top tier carts.
Besides, Ked, you haven't heard the Etna SL (if I'm not mistaken). Supposedly a big difference between the non SL version.
It might be fair to say the A95 is eclipsed by the others as it's a much lower priced cartridge, but even there they might be those who prefer it over the others (not me, I'm sure ).
