How is the sound coming along ? Have you found a good placement for the speakers ? How far from the front wall did the tweeters end up ?Finally taking the plunge into network streaming, with this EMM Labs NS1.
Proprietary optical cable to my DV2 Preamp/DA.
Very much the same distances i have when i use the internal bass drivers. I recommend trying no toe in also, it won’t change the center imaging to much unless you are sitting really close , but is best for bass integration in my system. Maybe because of the front ports being the only place the low bass exits the speaker.Thanks, Guys.
Current positioning is :
47" out from Front wall
40" from side wall
Spacing is 105" (approx. equilateral triangle listening position)
Speakers are toed-in to face listener.
A couple of things that helped with bass response was :
Plugging amps directly into wall outlet.
Removing corner tube traps.
Switching speaker jumper to Attack position.
Overall imaging is getting better, as well as the lower bass response.
I do have to admit I miss the incredible low end foundation of my past Evolution Acoustics MM3 speakers, with their internal (4) 15" subwoofers.
At a later date I may explore incorporating 1 or 2 subwoofers to satisfy my itch.
More to come later!
hello, can i ask you about your thaughts about the NS1?Finally taking the plunge into network streaming, with this EMM Labs NS1.
thanks for the info!Hi -
I just connected the NS1 this week and have it running in.
Using my iPad to control selections.
Seems to work seamlessly and sounds great thru the EMM Labs glass cable.
I never tried anything else and am a newbie to streaming - Using Qobuz.
Thanks,
Gregg
Currently using -@gfroman Thanks for pictures. Are you using AQ Dragons on with the M925s? Are you plugging the M925s in to the AQ 5000?
