Final Amplifier for Martin Logan CLX
I'm just teasing you David. You would make a great doctor with superb bedside manners. David the doctor to sick patient: "Don't buy any green bananas because you won't be around long enough to see them ripen."
Honestly, when I look at that blurry picture, I'm not even sure of what I'm seeing. What are those glass doors behind the ML speakers? Are those super tweeters mounted on stands between the ML speakers? Is that a turntable on the floor?
I know Mark, just kidding too, you shouldn't get me started on doctors with bedside manners and no medical skills...
You are right though these speakers weren't chosen for that old room
As I said in post #9:
ROOM TREATMENT, not bigger/better/different amplifiers is what you need.
Yes first photo is current room
Thx Gary
Suggestions about room treatment
I have never had a dedicated room before so first chance to do what i like
Hi all
I am new to this forum
Looking for advice on amplifier to drive my CLX
My main focus is classical
Timbral correctness and soundstageing are primary to me
Having difficulty finding a reliable amp that will run the CLX
I run a iDescent with the special crossover for CLX
Works well in my room 20ft by 12 ft by 60 ft
The problems I am having
Thinness with SS( violin especilly) and reliability from probably back EMF upsetting amplifiers
All tubes seem to run well with good timbral accuracy, resolution suffers, and clipping issues
The only one I was very happy with was VAC 200phi monos
All advice gratefully accepted
Warm regards
Andrew
Andrew
Their are many people on this form far ahead of me in audio knowledge.
But I do have the following to offer I have my room is 15 x 34 x 9 feet with CLXs and two decent i for amps I am using ayre mono blocks and ayre pre amp with a Burmester phono amp a Clearaudio statement table a triplaner arm.
IMO you have the following the Blue circles I know Gilbert well he has long been a Martin Logan owner I would give him a call for his input. Your room is very hard and is likely too live. I would get help the best help you can find to tame the room or do the best you can on your own.
If you like the CLXs keep them get a second decent i the Clxs are hard to set up so are the decents but well worth the time it takes my dealer and spent a day and a half getting it as right as we did. Few speakers at this price point are as good again IMO. You can see my set up on Martin Logans site under members systems title Garth again many can do all this better than me but any thing you see or ask right or wrong I will share.
Garth
I can imagine that room treatment for the CLX's should be left to people with large experience. I have listened to them sounding great and really miserable in different rooms, and can not understand the real reason for such differences.
Perhaps you can contact Art Noxon of ASC ( Acoustic Sciences Corporation) - I once read that he has experience setting up rooms with Martin Logan's.
Unfortunately here in Oz i am not aware of too many people with this expertise maybe people who build recording studios?
Yes I bought bc208 as Gilbert loves panel speakers
You need surfaces on your walls that will diffuse the sound. They are smooth and barren. The floor is tile or stone and is extremely reflective--it needs more carpet, the ceiling is flat and smooth, it need something to break it up a bit, but mostly rugs and wall treatments are what you need. Some curtains, even on the side walls will help.
I bet if you ran REW, you would find extremely severe ringing in the room.
I bet if you clapped your hands you would hear severe ringing in that room.
I agree my room got a lot better after the following 1 I put record shelves floor to ceiling behind the speakers. 2 Large crown mouldings around the room 3 a large t shaped structure centre of the ceiling for the drop screen and projector 4 a large rug . Each helped a lot I am still going ahead room treatments if I can find the help in what would work best. Their are hundreds of posts on which piece of wire is best but very little that helps in treating a room so many variables it is hard to go beyond first reflection points.
Or maybe I do not know where to look .
Garth
Thx all good suggestions
Infact the room if you clapped your hands or click your fingers doesn't ring at all
It's a live room for sure
There are absorbent panels on the front wall and sides next to CLX
Directly behind are record shelves
The issue seems to be at certain frequencies especially noticeable on some strings of violin
The floor is despite finish not very sound reflective
I think it's an interesting point to look at decay though
Did I see a refrigerator in your room??
Refrigerators are awful for injecting noise into the line, and their own physical noise with compressors going on and off.
I may have your answer just play Blues no violins may not be the answer you wanted but it is cost effective.
The Fridge isnt connected....
Need to move it out
Removalists dmped it there
Unfortunately blues isnt my thing ....
Sheldon methodology not disimilar to wilson audio speaker set up technique....
Need to remember that CLX dont radiate like a dynamic speaker
It makes no difference if it is connected. I was simply using it as a size and distance marker.
I know the CLX well, it's a dipole, not the same as cones, whose primary purpose is to hold ice cream!
. . . . The floor is despite finish not very sound reflective
Isn't the floor stone or tile? That's what it looks like. That is extremely reflective, and as a slab, probably 100% reflective.
