Goldmund Telos 690 Internal Dac
agencal
52
11
15
49
Istanbul
Hi
I have been using CH C1.2, X1, L1, M1.1 for some time for roon streaming to drive my Kharma Exqusite Midi 3.0. For budget reasons i had to shrink the system a bit and sold the Kharma’s and L1, M1.1 pre power and bought Goldmund Telos 690 integrated and Alara Labs Remiga 1 Diamond. I am more than happy for now but i wanna further with this shrink and want to ask you a question.
How is the dac on Talos integrated? If i sell CH C1.2 and X1 dac, do you think adding a great streamer to telos 690’s dac will collapse the the system performance? If it will Mola Mola Tombequie would be a good choice?
Hi
I have the 590 and used the internal DAC for about 1 1/2 years. The increase in sound quality switching to a $7,500 (got it for 6K new) Audio Mirror Dac was completely transformational. Two other tips: the chasis MUST be grounded to a good ground box to tap the potential of the amp. The feet it comes with MUST be loosened a bit for sound quality- my dealer did not tell me and I spent a year without the best possible sound. Enjoy!
Thank you. So internal dac is nothing special. Whichnspeakers are you driving with telos? How is the sound?
Hi
The CH 1.2 Dac is extremely good sounding unit.... I highly doubt you can do better than that at any price, you might get a different flavor of the sound like R2R chips vs FGPA or SAbre, etc, but to me, the CH 1.2 with its power supply is a keeper. However, we all hear differently, so the best bet would to try the Mola Mola in your system and compare.
Thank you. Actually i am more about shrinking the system and get some budget refund without much sucrifice of sound quality. I mostly like soundstage and holographic 3d imaging. Most of the reviewers say mola mola has a great holography. Thats why i am leaning twords that direction.
I am driving Adam audio speakers. They have an internal woofer amp so little current demand on amp. Sounds great but again would not say that without chasis grounding. I think because it is very wideband it creates it's own pollution which needs to be removed. In my expoerience room acoustics ( particularly diffusion on back wall) has a much greater effect on imaging than do the electronics.
