Luckily for those of us with a DIY bent, Ethan is remarkably generous with data and how to's.
Which very much alters the cost question asked originally.
The expense for the minimum to make an audible difference??
In my case, about sixty bucks. And in the end that was rather extensive treatment.
All I did was go and buy a couple of packs of fibreglass, crack them open and proceed to hang them around the room. Big room, hard walls, lots of echo and ring. Those issues became clear after treatment, it was 'just normal' before!
Anyway, not that these are permanent, but as seen by previous posts room treatment can be rather pricey, so what to do until you can experience for yourself how much change it can make?
Do as I did, just for an experiment, then after you hear it place your order with confidence. And then throw the batts into the ceiling and save on electrical bills!
Me? I will diy my own and make them look good.
I am now building PRD diffusors. They are on hold for a little while whilst I muck around with some system changes, then back into the shed to build some more.
Have built three, will build another three at least, but when I have six that is when I'll take them into the room and see how they go. I doubt one will make an appreciable difference, so will just have to be patient I guess.
