Graham Audio LS8/1 Signature Edition & a New System
Back to Benchmark AHB2 Amps
For the first time in the history of my audio hobby, I have purchased an amplifier for the second time. A few years ago, in my current listening room, I used a pair of Benchmark AHB2 solid state amps, bridged for mono operation with first my Harbeth M40.2 speakers and then my Gradient 1.4 speakers.
I sold that pair of Benchmark AHB2 amplifiers when I moved to active speakers, the Dutch & Dutch 8c, and later did not need separate amps with my Sanders 10e speakers since the speakers came with one Sanders Magtech amp and I logically purchased another to fill out the biamplified amplification needs of the 10e speakers. I sold both the Sanders amps as part of the sale of the Sanders speakers.
My recent experience with the 750-watt-per-monoblock Audio by Van Alstine AVM M750 amps showed me that I'm a power snob. While the smaller Van Alstine AVM M225 (225 watts per monoblock) sounded great in isolation with my Graham LS8/1 Signature Edition speakers, having heard the more powerful M750 made audible for the first time with these speakers the sense of unlimited power reserves which comes with yet more power on tap. However, while these amps sounded yet better than their smaller siblings, in my system they made way too much noise through the speakers--mostly hum--to be tolerated long term. Thus, I returned the M750s for a refund. As jonstine's comments above and elsewhere on WBF suggest, this noise problem with the M750s may be just a peculiarity of my set up.
Very few amps are truly silent in terms of quiescent hum and noise, in my experience. Usually, with no music playing, if I put my ear an inch or two from the drivers I can hear some noise. I forgive such noise as long as it is inaudible from the listening position, which, in my case is some 55 inches from the drivers.
Thus, my goal in replacing the Van Alstine DVA 750 amps was to acquire amps which provided a similar "endless power" sensation, while still being silent, both in terms of audible chassis hum and audible hum, hiss, or other noise through the speakers.
I know that the powerful Sanders Magtech amps usually are not silent enough. When I once used them with my Harbeth M40.1 speakers in another room of my house, I could hear hiss from several feet in front of the speakers. However, they work in a noise-free manner as part of the Sanders 10e system where they are combined with the dbx VENU360 Loudspeaker Management System. That unit can very effectively act as an input gain control for the power amps, providing, as it does, analog domain controls for both input gain and output voltage. Thus, the dbx can easily lower the effective gain of the Sanders amps so that hiss normally audible through the speakers is silenced. Part of proper gain structuring of a professional audio system is using high gain sources, together with a gain control/volume pot or pad at the amplifier input to allow the gain of the amps to be turned down to just a few dB. This lowers the noise and increases the signal to distortion and noise audio throughput of the system. The Sanders system is unusual among consumer audio systems in allowing for this sort of gain structuring.
The Benchmark Media company, having a foot in both the pro audio and consumer audio camps, provides a gain control switch on its AHB2 amps. In its lowest gain position the AHB2 amps have the truly low gain which ensures compatibility with the high source voltages used in pro-audio system. At this setting the amps require 9.8 volts input for rated output power. While my Lumin X1's rated output is only 6 volts, I know from my prior experience with this combination that the low gain setting goes loud enough with all source material in my room, as well as sounding best and providing the absolute least quiescent noise from the speakers. See my comments on this arrangement here. The Benchmark amps are extraordinarily quiet with any setting of the input gain switch. I hear no transformer hum from the amp chasses with my ear closer than inch from each chassis. And in their low gain setting, I hear absolutely no hum, hiss, or other noise from any of the speaker drivers even with my ear on axis with any of the speaker drivers and within an inch of the speaker grill cloths. This applies for any setting of the Lumin X1's Leedh-processed digital volume control.
My sonic evaluation of the Benchmark AHB2 amps is unchanged since I last used them. If anything, system improvements in the interim have only further revealed their level of sonic refinement in terms of perceived lack of background noise, clarity, lack of distortion, immense sense of power reserves, lack of coloration, three-dimensionality, envelopment, etc. See my 2018 discussion of the AHB2 sonics here.
In the years since its introduction, some, while acknowledging its matchless specs in terms of low noise and distortion combined with remarkable power output given its small and light form factor, have criticized the Benchmark AHB2's sonics by saying it is lacking in macro dynamic swings. I hear this, but I hear it differently and hear it as a plus for the Benchmark. The Benchmarks lack the overblown-sounding midbass of some other amps which can provide a sense of greater dynamic power. It also lacks the ultimate degree of "splash" on large transients which some interpret as a dynamic limitation. I think this "splash" is actually caused by a blast of slightly distorted sound in the higher frequencies. The Benchmark is ever precise, controlled, and clean, clean, clean, which amounts to "beautiful" sound in my book. Likewise, the Benchmark midbass is fully ample and certainly not lean in any way, just more controlled and defined/less distorted. This "uncovers" the Benchmark's lower bass, revealing more detail, definition, and power in the bottom two octaves.
In terms of size and weight, as well as cool running, the Benchmark AHB2 is roughly equivalent to the Audio by Van Alstine DVA M225. The form factor is a bit different, that's all. The AVA is narrow and deep. The Benchmark is wider and less deep. They are both easy to carry and fit well within my "downsized" system form factor goals. However, the Benchmark AHB2s, used in bridged mono, give that "limitless" power impression, whereas the AVA does not. And while the AVA is quiet enough running, the Benchmarks have noticeably more silent backgrounds. The AHB2 are, for all practical purpose, absolutely silent runners, totally concealing the vast power on tap.
Continued…
While I understand the need for attenuation is system specific, and not necessarily a requirement for everyone, they have made a huge impact with what’s being sent from the Lampi to the amps.
The SR Purple fuses are specific to the M750s however, and as long as you orient them the correct way (in my case both fuses have the “S” in SR closest to the fuse knob or exterior of the chassis) they make a difference. I’ve got the SR Master fuse in the Lampi, but not sure that I want to buy 2 of those for the M750s. I suspect they would be better, but that’s a huge price jump for 2 of them.
Regardless, with the addition of the SR Purples and the Rockwell attenuators, at 200 hrs the M750s are singing better than ever, and I am incredibly pleased with them. What a hobby!
Bass Extension & Power: Can You Have Too Much of a Good Thing?
The potential bass extension of the LS8/1f floor-standing version of the Graham LS 8/1 model (see https://onahighernote.com/shop/spea...ing-model-of-the-derek-hughes-ls8-1-monitors/) is a potential plus, at least for some rooms. The floor stander currently lists for $11,500 in the USA.
For my small room, I'm no longer so certain. I have had several speakers in this room which measured flat-in-room to 20 Hz or below (Dutch & Dutch 8c, Harbeth M40.2, Sanders 10e, Gradient 1.4, Stirling LS3/6 + Swarm Sub quartet, KLH Model 12, AR-3a). The Graham LS8/1 may not measure flat in the bottom octave, but subjectively the bass from these sub-less speakers is every bit or more as satisfying as any of those others in my small room. In my room, the Graham bass strikes an exemplary balance between actual extension and cleanliness and detail, not audiby exciting structural resonances from the room and having no audible speaker-box or driver resonances to muddy up the low end.
Also, I note from the specs that the LS8/1f model is just about one meter tall. That's at least two inches shorter than the stand-mount model on the Graham stands. That means the tweeters and best listening position are another two inches lower, making the lower tweeter only about 32 inches above the floor. This means that either tall footers or tilt-back of the speakers would be mandatory for near-field listening.
Someone noted that the low-height problem of the floor-standing version of the floor-standing version could easily be dealt with by adding a platform of substantial thickness, such as a cinder block, between the speaker and the floor. That's a good point. Standard cinder blocks are 8" x 8" x 16". That only gives you two choices of additional height. With a 32" tweeter height for the speaker sitting on the floor, that would give you options of 40" and 48". The first is quite reasonable for a normal domestic chair. The second is a bit high for something other than a high stool.
There are obviously other options such as lumber of various sizes. For more money, there are also handsome purpose-made audio platforms made from maple and walnut (see, for example https://butcherblockacoustics.com/collections/audio-platforms or https://www.mapleshadestore.com/airdriedmapleplatforms.php. In addition, granite or marble platforms are a possible attractive alternative. The Tontrager website for the reference stands intended for Harbeths says that the stands optimally should be set atop slate plates; see https://www.tontraeger-audio.com/lang/en/produktdetails-stands.html
Any "rocking" problems at the interface of speakers and supports or supports and floor should be addressed. I know from experience that allowing your speakers or their supports to "float" atop carpet, rather than spiking them to the floor beneath the carpet, takes care of any rocking/resonance problems at that interface. I also know that putting a layer or two of terrycloth toweling between the speaker and the wood or cinder block support should prevent any rocking/resonance at that interface.
I do wonder, however, how much the sound of speakers is affected by changes in the speaker height. Perhaps electronic EQ could address any adverse effects.
I noticed when I moved the Graham LS8/1s from my initial stands--Skylan stands which had a solid top plate, 20 inches off the floor--to the Graham stands which are 4+ inches lower and have no top plate, and lowered my listening height by the corresponding amount, that the sound from my new lower listening position warmed up in the midbass and lower mids. In my installation this was all to the good.
I have to wonder how much of this sonic change was caused by (1) the lower Graham stand height, or (2) the lack of a top plate on the stand, allowing the speaker cabinet to resonate more into "free air", or (3) my lower seated height. I did not attempt to separate these effects. But I suspect that at least for some speakers in some rooms, changing these factors alone or in some combination can be expected to produce sonic changes, sometimes for the better and sometimes not.
But another reason for my switch to a smaller speaker from the Sanders is the difficulty of moving heavy and bulky speakers in and out of my listening room and navigating the right-angle turn in my stairway getting speaker boxes up to my second floor listening room. Since I change speakers every year or two, this is a practical consideration for me.
The floor-standing LS8/1f does not occupy any more floor space than the stand-mount version, but it is heavier and the box is much larger. I no longer want to wrestle large heavy boxes up and down the stairs. The two stands of the Signature version of the LS8/1 are nested in a single box about the same size and weight of one of the speaker boxes, so those boxes are all manageable.
I also believe that stand-mount speakers have an advantage over floorstanding versions because of the way the stand allows the drivers and enclosure to be surrounded by vacant air, improving the staging and imaging. Further, I'm pretty sure that the longer larger wood panels involved in making a stand mount into a floor stander create bigger challenges for eliminating box resonances. Boxes of dimensions like the two-cubic foot Graham and its ancestors (basically two feet high and one foot in the other two dimensions) seem to have an advantage in terms of dealing with box resonances. Measurable resonances certainly are there, but they are not obnoxious to the ear.
The lossy screwed-together construction of the stand mounts would seem to be a better approach than the glued-together construction of the LS8/1f, but it could be that once the shape and size of the box is changed, the glued construction/MDF may actually be equivalent. We'd have to see accurate box resonance measurements to be sure.
I'm not sure if what I hear in my small room from speakers with greater bass power/extension than the LS8/1 is what others call "room roar" or "overloading" the room with bass. But if I disconnect the high frequency drivers (easy with the Sanders given its electronic controls and many speakers with bi- or tri-wire connections) or just EQ the mids and highs way down in level, it is easy to hear room contents and parts of the building structure within the walls and floors, and even my hot-water heating pipes and registers, buzz or resonate with bass.
With some speakers with 20-Hz-flat bass extension I've used in this room (the Sanders 10c and 10e, and the Gradient 1.4 in particular) it was also clear that the bass drivers and cabinets buzzed or resonated when reproducing bass tones even when the SPL was down around a measured 80 dB. The Dutch & Dutch 8c cabinets and drivers were exemplary for not producing any spurious mechanical noises regardless of SPL or frequency, but the structural buzzing room resonances were still there in full force.
With the LS8/1, I hear nothing but clean sound from the drivers, cabinets and room at any SPL I care to listen. And given the frequency balance of the speakers in my room, I'm not always trying to crank them louder to bring up the bass or hear more upper range detail. I'm sure that helps keep the in-room sound clean.
Equalization: None vs. the Schiit Audio Loki Max
But then about three days into my audition, I began to have my doubts. Something was wrong. I still heard no real difference between the processing turned on but with the bands all set to flat and the electronic bypass of all the filters. But the tremendous sense of spatial envelopment I remembered having before adding the Loki Max to the system seemed reduced. In addition, recordings seemed much less dynamically unrestrained than before.
I did an experiment to enable a relatively quick A/B comparison.
This effectively took the Loki Max physically and electrically totally out of the signal path, bypassing the relay and resistor which Schiit says are the only electronic components still in the signal path when the bypass mode is enabled.
The sonic change was unmistakable. Now, even with the extra 1/2 meter balanced cable and its extra XLR connection in the signal path, the space and macro dynamics I remembered from my unequalized system were back. The difference was instantly audible and clearly "better" rather than just a difference.
For now I will eschew all electronic equalization in my new system.
Your opinion may well differ on that judgement. Your system may well not reveal the level of space/envelopment and dynamic contrasts my new system does. Certainly my prior Sanders system did not.
Hello!
Do you have a theory as to why the Loki Max obscured or eliminated ambient spacial cues and restrained macrodynamics?
Have you ever experimented with the Manley Mid-Frequency EQ device?
The sonic effect I heard must have been due to the relay and resistor left in the signal path with the Loki Max physically connected. As I noted at the time in post #3 of this thread, the sonic problem went away when I physically removed the Max from the signal path by connecting the balanced input cable directly to the balanced output cable. I did not investigate further since by that time I was also quite disgusted with the, to me, totally inadequate user interface which I detailed in post #4 of this thread.
And, no, I've never experimented with the Manley Mid-Frequency EQ device. As I've mentioned before, I do not buy tube equipment. The sharp Q equalization description of what the unit does from the Manley website does not sound like something I would want to insert in my signal path.
Thank you!
I wonder if the RC or RL switched in by the Loki Max positions introduces some phase anomaly which obscured or undermined ambient spacial information with you previously were hearing.
A sense of dynamics no longer being unrestrained perhaps could come from the inability of the Loki Max to swing voltage to the extent of your line stage's ability to swing voltage.
Another Tweak
Back in Post #45 I listed a number of sonic tweaks which improved my streaming sound. Here is another tweak I recently discovered which seems to improve the sonics I hear when streaming via the Lumin App as opposed to Roon. In my system, streaming via the Lumin App sounds at least a bit better than streaming via Roon. This tweak might also help when streaming via other proprietary streaming software where the Roon Ready function of your streamer can be turned off as is possible in the Lumin App.
1. In the Lumin App Options menu, turn off "Roon Ready" if Roon is not being used.
2. In the Roon App on the computer which acts as your Roon Core, under Settings>Audio, disable all device choices.
3. Close and exit the Roon App on the computer which acts as your Roon Core. Then, turn off that computer.
4. Open the Roon App on your system controller (in my case, the iPad which controls my Lumin X1 streaming DAC). In this Roon App, under Settings>Audio, disable all device choices. Then close this Roon App and exit from it (swipe up on an iPad).
In my case, I had long been practicing steps 1. through 3. I only recently discovered that step 4., disabling all the device choices in the Roon App on the system controller, was a key to yet-better sound from the Lumin App. I have no idea why this matters, but it seems to make a positive sonic difference, in my system, at least.
Enter the Lumin L2 Music Library & Network Switch
Over the last couple of years, I have mostly listened to my own music files ripped from my CDs via Roon. Those music files were hosted on my Mac (or before that Windows) computer and played through my stereo room rig via Roon. This is because I determined that attaching USB or even ethernet connected devices to my Lumin X1 streamer had detrimental effects on the sonics I heard from internet streaming from Qobuz, Tidal, or even internet radio stations. This was true even with the earlier Lumin L1 music library.
Over that time I gradually came to the conclusion that optical filtering via my GigaFOIL v4 INLINE Ethernet Filter inserted in the signal path just before my Lumin X1 was the best way to "clean up" the noise and other nasties otherwise audible from streaming sources via the X1 and the Lumin App. This also provided the best sound I've heard in my stereo room from Roon (Tidal, Qobuz, internet radio, and my local music files). In my installation, which involves a 90+ foot run of ethernet cable from my router, the GigaFOIL can make a subjectively HUGE improvement in sound quality as I've discussed in earlier posts of this thread, such as #5.
I heard the Lumin L2 at AXPONA 2023, however, and was quite impressed with its streaming presentation even under difficult hotel show conditions. When the L2 was actually released to consumers I became even more interested in its potential to isolate both itself and the Lumin X1 from conducted internet noise via fiber optical links. Recently I decided to pull the trigger on purchase of the L2.
Yes, it's expensive, at 4,500 USD for the version with 4 TB of built-in solid-state storage which I purchased. It's 3,500 USD with no storage and 5,500 USD with 8 TB of built-in solid-state storage. But for the first time the Lumin App now delivers both the best sound I've ever heard from my owned local music files and the best sound I've ever heard from all internet sources--Qobuz, Tidal, and internet radio stations of every ilk.
For a diagram of the streaming signal path I'm using, see the second diagram at this link. I'm using all of Lumin's recommended fiber optic pieces. The details are: Xfinity Gigabit internet service, feeding Xfinity xFi Advanced Gateway, feeding 90 feet of CAT6 shielded ethernet cable, feeding 5 feet of Blue Jeans Cable Cat 6 Patch Cords ethernet cable, feeding TRENTNet TEG-S51SFP 4-port Gigabit Switch with SFP Slot powered by 5V output of Keces P3 LPS, feeding Startech SFP Module feeding one meter of LC-LC Duplex 9/125µm Corning ClearCurve Single Mode Bend Insensitive Fiber Optic Patch Cable, feeding Startech SFP Module, feeding Lumin L2 Music Library & Network Switch, feeding Startech SFP Module, feeding one meter of LC-LC Duplex 9/125µm Corning ClearCurve Single Mode Bend Insensitive Fiber Optic Patch Cable, feeding Startech SFP Module, feeding Lumin X1 streaming DAC. The Leedh-processed volume control of the X1's balanced analog outputs directly drive my Benchmark AHB2 amps which directly drive the Graham LS8/1 speakers. No preamp, no electronic EQ.
Note that the additional cost of creating all this fiber optic isolation around the Lumin L2 and X1 is about $300. That's the total for the TRENDNet switch, four SFP modules, and two fiber optic cables.
The GigaFOIL is gone since it's optical isolation is now unneeded given the fiber optical connections I'm now using.
The Lumin L2 makes my system sound better yet than the GigaFOIL did. Not a huge difference, perhaps, but it's quite a substantial difference. And it's all in the right direction of making things sound yet more three dimensional, natural, and relaxed, while yet adding more audible musical detail without adding any high frequency brightness or nastiness. Musical lines are easier to separate/hear out and in fact often I hear musical lines which seemed totally buried before. With classical music, the result is "more like analog." What I mean by that is that the sound is more like unamplified live music heard from a great seat in a favorable venue in terms of perceived lack of distortion, clarity, subjective frequency balance, three dimensionality, and dynamics.
There's more. I'm still discovering the wonders of the Lumin L2. There's more improvement than I first thought. Music flows better and makes more sense rhythmically. By comparison, the timing of the music was a bit "off" before and now it's spot on and much more engaging. I hate to bring up the old PRaT concept, but that's another aspect that seems to have been greatly improved.
With the addition of the L2, I'm yet more convinced that many who insist on using electronic equalizers to tame the excessive highs of the majority of commercial recordings are in fact reacting at least partially, if not primarily, to the high frequency nasties present in most digital signal paths, not so much to the absolute level of the highs. Sure, many recordings still sound brightly balanced with the L2, but tonal brightness with the nasties so much reduced is entirely listenable and not worth electronically equalizing when such equalization adds sonic problems of its own. At least that's the way I hear it.
There were some flies in the ointment in terms of getting my music files loaded onto the L2. See this post of mine over on the Lumin forum and the responses of others to it. I would not have had any problems had I been aware of the need to add third-party software to my Mac before attempting to drag and drop files from my Mac hard drive onto the NFTS-formatted L2. And now it seems that Peter Lie, Lumin's Firmware Lead, says in a response he posted, that the SMB method of adding files to the L2 is the way to go anyway, being superior for the L2 than the drag-and-drop method that gave me such problems. You don't need any extra software to add files to the L2 via the SMB method. If you decide to take the L2 plunge, you will be forewarned and forearmed.
But now that the music is loaded, those teething problems are rapidly receding in the rear-view mirror. I'm basking in the glow of the best sound I've yet had in my stereo room.
Reactions: jonstine
I have the Graham 8/1s as well. I have gone a different route with amplification -- I am using a Luxman mq88. My previous experiences with British monitor speakers taught me that the least complicated route to great sound was quality, moderately high powered SS amps. I was surprised by the apparent synchronicity between the 25wpc Luxman and the Grahams. Then again, the Grahams are more transparent and less warm than the older Harbeths I have owned, and have a better, more natural bass response than the Ls3/5as. Maybe it's the apparently stable impedance curve and the relative small room they're in. I am currently loving the combo, more than I enjoyed the Grahams with the LFD NCSE or a McIntosh 2105.
Great write up! I’ve listened to BBC designs since the mid 80s when as a grad student I bought a pair of Spendor SP1s. I now own the SP 1/2e and the Harbeth Monitor 40.1s. But my first love has and always will be with Quads (I own three pairs, the 57s, the 2805s and the 2905s). I find the crossover induced effects of the BBC designs too distracting. The change in directivity is also problematic. Ultimately I don’t think the BBC designs can overcome the theoretical limitations of the basic design, however clever the skullduggery in the thin walled cabinet construction and the polymer cones.
I thought I might consolidate some information from other threads here just to bring this thread up to date as to my "new system."
To my mind, the most sonically significant improvements I've made lately are:
1. the fiber optic networking and Lumin L2 Music Library talked about in post #68 above
2. the improvements in Roon sound I've made through the purchase of the Poor Man's Roon Nucleus Plus and siting it outside the audio room (discussed in my Making Roon Sound Better thread); and
3. the use of Farad Super3 linear power supplies both for that Poor Man's Roon Nucleus Plus and to power the TrendNet ethernet switch in my audio room, replacing the Keces P3 I was using there.
The major change I've recently made is my current switch from the Graham Audio LS8/1 speakers to the Watkins Generation 4 speakers talked about in my Watkins Generation 4 thread. I still have the Grahams and plan to return to them at some point. . . but not yet.
Here is a descriptive list of my current audio hardware. This is taken from this post of My Current Audio Systems thread which I've tried to keep up to date as I make system changes:
Reactions: billt1
Thank you for this detailed update!
I have made a further improvement in the sound of the Watkins Generation 4 speakers in my system. As noted in the information about the speakers on Watkins' website, the speakers have a bit wider dispersion than most in the mid and high frequencies. As with past speakers, I have employed about 128 square feet of natural white Acoustical Solutions four-inch-thick AlphaSorb Flat Foam acoustic foam covering first-reflection areas of all walls of my listening room.
I usually have not treated the "popcorn" finish ceiling (beneath the "popcorn" finish is plaster) since this finish provides a bit of dispersion of high frequencies on its own and because with relatively short speakers like the Watkins and Graham LS8/1, the ceiling is more than five feet away from the speakers. Also, the popcorn finish makes it is difficult to mount foam bats to the ceiling "temporarily." Neither staples nor the stickiest of tape or velcro work very well as I've found from past experiments.
At to the floor reflection, I have usually relied on my plush pile carpet and pad to absorb reflections from that surface. I know that is not ideal, but with several recent speakers, I haven't really noticed any sonic improvement when placing the acoustic foam atop the carpet in the first-reflection areas. The Sanders 10e, for example, has VERY limited vertical dispersion so reflected very little sound from the floor or ceiling. Also, due to my near-field listening position (ears 59 inches from the speaker drivers), the first reflection of the speaker baffles from the floor as viewed from my listening seat is very close to my feet. It thus is difficult to site enough foam on the floor and still leave room to safely put my feet while sitting in the listening chair, much less safely get into and out of the listening chair. The foam is both a trip hazard and due to its melamine nature, it is easily damaged by physical contact with feet or shoes.
With the Watkins speakers, however, I noticed significant acoustic benefits from placing acoustic foam on the floor. This is probably because the Watkins disperse more high frequencies downward than the Sanders 10e and Graham LS8/1 I've also used in this room in the last year. Thus, I set about experimenting to see if I could size the foam pads so that they both did enough acoustically to make a significant sonic difference and stay far enough away from my feet to be safe both for me and for the foam.
The size of the first reflection spot of each of the small Watkins speakers as viewed from my seated listening position fits within the size of my rectangular 4" x 6" flat mirror placed on the floor. After experimenting with cutting down the standard 24" x 24" acoustic foam pad, I found that the pad could be no larger than 12" wide by 24" long for safety. That pad is still three times wider than the reflected image of the speaker width and four times longer than the reflected image of the speaker height.
To make sure the floor pads were optimally placed, I drew lines on the top side of each of the two pieces of acoustic foam, bisecting the length and width of each foam piece. Then I placed my 4" x 6" flat rectangular mirror exactly centered in the "crosshairs" of these lines, orienting the mirror to be parallel to the sides of the rectangular floor pad. I then moved the floor pad until the image of the speaker seen in the mirror from my listening positon was exactly centered in the mirror, with the image of the speaker's sides, top, and bottom parallel to the sides of the mirror. The attached picture shows approximately what I see with my right eye looking at the reflection of the right speaker from the mirror centered in the floor pad.
While it would be even better sonically to have a 24" x 24" acoustic foam pad at each first-reflection area on the floor, I have determined experimentally that even this pad, which provides only two square feet of foam absorption for the floor reflection of each speaker rather than four square feet, makes a substantial improvement in imaging and staging.
Specifically, the sound is yet freer from the physical positions of the speakers. Depth of field is substantially deeper. Envelopment around the listener on recordings where phase is manipulated or where significant hall ambiance is captured is increased. Generally, the spatial presentation sounds more three-dimensionally "solid" and image placements are yet more anchored. Tonally, high frequencies sound yet cleaner, more focused, more integrated into the rest of the sound, and yet better balanced with the lower frequencies.
One very useful tweak of the Benchmark AHB2 Amp sound, which I think can ameliorate any objections to its sonic presentation is the use of AV Room Service Electronic Vibration Protectors ('EVPs) in place of the amp's stock feet. Why this simple change has a more profound effect on the Benchmark's sonics in my system than on other electronics, I do not know, but there it is. I suggest trying this if you have any reservations about the sound of the Benchmark amp (in my case, a pair of them, run in bridged mono mode).
Remove the two stock rear feet using a #2 Phillips or Pozidriv screwdriver. Replace them with 2-inch square HD (High Density) EVPs. Place them in the rear corners just inboard of the black casing--at the rear corners of and on the silvery bottom plate, in other words. Then center a third 2-inch square HD EVP along the front edge of the silvery bottom plate, just inboard of the front panel. There is no need to remove the two front stock feet of the amp.
That's it. Now see what you think of the sound. Many aspects of the sonic presentation seem yet better in my system, including dynamic headroom and dynamic swings. This is despite the fact that I was already using separate Bright Star Audio Little Rock isolating platforms beneath each amp.
The amps actually seem to be yet more unlimited in their power reserves with this tweak. Using the amps without this tweak with the Watkins Generation 4 speakers (as opposed to the Graham LS8/1s) I was occasionally aware of a bit of high-frequency transient crunch at high SPLs. When I heard this, I would just turn down the volume a notch and this problem would vanish. At first I thought this was just due to dynamic limitations of these rather-small Watkins speakers. But with this tweak, this problem vanished and the speakers play as loud as I want on any material without any apparent "crunch." The apparent frequency response with the Watkins speakers further smooths out when supported by EVPs, the stage expands in all directions, images are yet more focused, the bass further extends and warms a bit.
Unfortunately, this tweak is not as inexpensive as it used to be. When I purchased my EVPs, they were only $40 each. Now they are $119 each. Still, for owners of one or two of these amps, I regard using the EVPs as capable of producing a significant sonic improvement.
Dear friends, I have a small doubt. I saw some versions online, which are also signature editions. The screws on the panel are golden, while most are black. Is there any difference in the quality and material inside the sound?
Thanks!
On my pair, the screws holding the rear panel are golden while the screws on the front baffle are black. I very seriously doubt that the color of the screws used is any sort of indication about the sound of the particular pair of speakers in question.
I strongly suspect that the variation in screw color is either (1) a matter of using whatever properly specified screws were available at the time of assembly (supply chain issues and all that) or (2) a matter of aesthetics.
The #035 pair you show is much earlier than the #103 pair I have. It could be that the gold baffle screws proved to show through the grill in certain lighting conditions to the detriment of aesthetics. For these speakers, the grills should definitely stay on for best sound.
And if for some reason you want to operate the speakers with the grills off, the gold screws are an aesthetic annoyance and distraction, at least to my sensibilities, since they stand out so much against the black baffle.
Thanksfor your reply!
What I am worried about is whether the different colors of the panel screws imply different materials inside, and these golden screws are particularly in the Chinese market.Recently, there is a pair of second-hand from 2022 with signatures, but there are some mold spots on the low-frequency cone that cannot be removed due to dampness. I wonder if it will affect the sound quality. Considering buying.
Certainly I like the black panel and black screws. Too many gold dots on the black panel, too ugly.
I suggest that you contact Graham Audio to get their comments and opinion. My experience, as well as that of others who have asked questions of Graham staff, is that they are very responsive and helpful.
Following up on my finding in post #74 above, I experimented with the number and placement of EVPs under my other audio electronics. It turns out that in my current system (as opposed to my original findings in my prior thread dealing with EVPs) the tripod arrangement of these very helpful devices works sonically best under most of my other electronics as well. Before, I usually was placing four of them in a rectangle under the component, usually under the chassis corners, but so as to avoid any non-removable stock feet of the component, placing the EVPs directly against the chassis.
The placement directly against the bottom of the chassis still seems sonically best, but my sonically preferred arrangement is now two at the back edge of the component as near the back corners as I can get them and still avoid non-removable stock feet (I remove stock feet when easily possible). The back of components is usually the heavier end, or at least it exerts more torque on the EVPs since all the wires connect there. I center the third EVP along the front edge of the component chassis.
This change necessitated using different versions of the EVPs than before in some cases, given the weight of each component, the reduced number of EVPs, and the rated load range for each EVP. See the EVP Selection Chart on this page. Where the load rating of the EVPs would allow more than one version, I am now tending the use the higher-load-rated version. These are easier to move into place under the component chassis and have less vulnerable "bellows" so that such movement does not tend to damage the bellows. I prefer the EVPs with rubber tops and bottoms to the felt versions. While the felt version is very easy to more around underneath components on rack shelves, this ease makes it more difficult to position each EVP exactly where I want it and allows the position of the component on the shelf to unintentionally shift with even slight lateral force. Things stay where I want them with the rubber EVPs.
The only electronic component now not supported by a triad of EVPs is my small and very light TrendNet ethernet switch. It is so light that even with the low density (LD) EVPs, the supported weight is only within the rated load range if a single EVP is used. Thus, for that component, I use only a single Low Density EVP carefully placed beneath the small chassis of the switch so that the bellows are equally compressed left to right and front to back.
Sonically, there is subtle "cleaning up" of the sound--even less "edge" and perceived distortion--plus firming up and clarifying of bass lines, more resolute imaging, and further three-dimensionality added to images and the soundstaging so that the sense of envelopment in the acoustics captured by the recording or added through processing is enhanced.
I freely admit that I change components rather frequently, especially speakers. But I usually only change components or tweak things further when I think I hear something wrong, however subtle or slight. Right now, I don't hear anything wrong, but instead get great excitement and hear wonderful sonic and musical beauty from my system. So, for the moment, I'm as content with the sound as any audiophile can be.
There were two major recent upgrades which, to my mind and ears, crossed over some threshold and allowed me to stop hearing things at least very subtly "wrong." One was the incorporation of the L2 with the Lumin-recommended fiber optical networking of it and the Lumin X1.
The other was finding two speaker systems, the Graham Audio LS8/1 and the Watkins Generation 4, both of which provide not only a clearer window on what's upstream, but also eliminate so many distortions and resonances present at least to some minor extent with all previous speakers I've owned. The Graham goes deeper and may be more satisfyingly weighty for large-scale classical music, so I may go back to it at some point, but the Watkins is, at least for now, the most bewitchingly beautiful and exciting.
A third important factor was discovering that with my current system configuration, the EVPs I'm uses for vibration isolation sonically seem to work best in a tripod arrangement, rather than in groups of four.
Getting better system sound from here will be more difficult since I will not be trying to eliminate audible problems but actually to improve further on what already sounds truly excellent to me. Distinguishing better from just different is more challenging than eliminating sonic annoyances.
I only wish that it had not taken so many years and such expense to get here. While my current system costs under $50,000 total (including both sets of speakers), over the course of my audiophile career (about 1966 to the present) I recently calculated that I have spent at least $700,000 on audio equipment, recouping only a small fraction of that amount in sales.
My current system configuration is here.
