Hi everyone, first i would like to apologize if my english is not very good since i'm french.
Here is my components :
Audio card : Behringer U-phoria UMC22 (I also have a Focusrite Scarlett 2i4)
Monitoring headphones : Beyerdynamic DT 1770 pro
Speakers : Behringer MS40
So here's my problem. I make music on FL Studio, and until now i was using my Speakers with a virtual audio card and it was working fine. I just received my Monitoring Headphones today, so I wanted to use one of my two audio cards to plug both my speakers and monitoring headphones as i wish to do music, mixing and mastering. The speakers work just fine on both audio cards, and i don't hear any "white noise". But when i want to use my headphones, i have the hissing or "white noise" when my headphones are plugged to my speakers. I noticed several things :
- If i plug my headphones to te audio card, there is no white noise, but i don't have the same sound as if my headphones were plugged to my speakers. Meaning, I don't benefit from the "bass" and "treble" sliders (I think it's called sliders ? If you know what i mean it's the 2 "buttons" i can slide to boost or reduce bass and treble) But i want to benefit from those, since i want them to be exactly at the speaker markers for my mixing and mastering.
- The white noise is reduced or amplified when i turn down or up the "treble button" from my speakers when my headphones are plugged to my speakers.
- I checked with my two audio cards, same problems, no difference.
Can anyone help me ? I would like to use my headphones plugged to speakers to benefit from the trebel and bass buttons while completely removing the white noise.
Thanks for your time !
