Does Tonal Balance Affect Perceived Pace and Perceived Resolution?
I agree that if one is coming to the party with a SET under their arm, then speakers that are appropriate for them is a good idea.
But if one already has hard to drive speakers, then a SET is not something that they should have under their arm when walking out of the shop.
There are a number of “high end”speakers that have 4 ohm drivers, and difficult crossovers.
These make life pretty challenging for many amps.
It is certainly a lot easier to find a solution with having easier to drive speakers, and avoid being railroaded into the esoteric/arcane amps.
Hard to drive speakers are not good for solid state power house amps either. Regardless of the amplifier technology it will always make more distortion into lower impedances. So 4 Ohms will not allow you to get the most out of your amplifier dollar investment.
Phase angles should not be ignored either- they cause amps to make more distortion too. Finally, speakers that are 4 Ohms in the bass but 8 Ohms elsewhere tend to make amps produce more distortion in the bass region (where the power is) which harms the ability of the system to be natural/accurate in the mids and highs.
Speaker designers really don't like to hear this sort of thing, but they should probably be looking at this from the perspective of the amplifier rather then the other way 'round, and if working with an amp designer, do so with one who will be honest with them and himself.
The amp should be loafing for a job, kicked back on the beach with an iced limeade in hand. What is thus essential and is really the case even with hard to drive speakers, is a very good first Watt (harder to drive speakers might need a really good first 5 Watts...).
Reactions: Holmz
OK - but the speaker designers are railed onto the 4-ohm supply line, for woofer drivers.
If ^this^ is true (which it is), then why does everyone seem to ignore, or overlook it when selecting a speaker?
All good points Ralph.
Maybe there is a “best amp” for bad speakers”, or a “best amp” for easy speakers.
Or maybe some best speakers for average amplifiers.
The only thing I have gleaned from this thread is that:
- Many people do not feel that time and phase correctness of the speaker is important.
- Many do not appreciate that distortion helps the system to sound loud.
- Many do not appreciate that distortion can make the system fatiguing.
Reactions: Atmasphere
Disagree with all of that.
I know.
I am assuming that you disagree with the content, and not disagree with the “Many” part…
And as Ron pointed out in his post, the idea of “a system sounding quiet”, was something foreign to him.
Thank you for replying to my post. But I don't understand your post, and it does not sound correct to me. "Higher distortion speakers for lower level listening"?
Low distortion amps and speakers need to be turned up loud?
Systems that sound quiet when they are not quiet?
I have no idea what you're talking about.
Surely it cannot just be myself and Ralph that have noted this.
Just for decades I was not 100% sure the reasoning, but had correlated a “quiet system” with “a good system”.
And there have not been a lot of system that have exhibitied the charastic.
As far as I’m concerned you hit that nail dead center.
Reactions: Holmz
I know.
I think it's probably just an issue with communicating nuance across a screen and likely different languages.
- Nobody here has disagreed with the importance of time and phase correctness except at frequency extremes. Rob and I only disagreed on terminology for "time aligned". I meant it for the physical and electrical alignment for the drivers on the speaker baffle, Rob meant it for across different physical places in the room. Of course the latter is a near impossibility. but the former is speaker design 101 and a basic premise of how to get drivers to work together. I also assert the importance of "time alignment" is frequency dependent. The group delay graph Rob later posted shows this exact phenomenon, so it is in fact relevant. What's critical at 2 kHz is not so critical at 20 kHz or 20 Hz. AFAIK, you haven't clearly stated what you think except for liking 1st order crossovers, and seem to deny that our sensitivity to time depends on frequency, despite that view being contrary to conventional wisdom and scientific studies.
- On distortion, I think it's most likely Ron simply didn't understand how you worded your post. It's not just you and Ralph that have noticed, it's actually a basic concept that nearly everyone in the audio hobby is familiar with to some degree. I think it's fair to assume everyone reading this is familiar with the concept of even and odd order harmonic distortion and its effects.
Reactions: Holmz
Yeah @DaveC for being an English speaker, my written communication is not as good as it should be.
Personally in just hate the soggy sound you get from a good speaker being under driven by a tube amp, the distortion might not sound fatiguing but i still can't listen to it to long.,
Reactions: Mike Lavigne
Face it Milan, when it comes to amp speaker pairings for those Martin Logan Statement speakers, you can’t bring Shirley Temples to a bachelor party.
Reactions: bonzo75 and Lagonda
@ Ron Resnick your reel to reel system was very engaging. There was a fullness and throwback tape sound to that set up in your system. Great combination with the Amps and Clarysis speakers.
Well there is ^that^
Any time one cannot listen to it for long, makes for a telling fact.
There is no “absolute phase” everywhere in the room, we agree that that doesn’t make any sense.
Are you referring to my post #57 where I said:
Assuming that there is PRAT, and that it is something with timing or rise time, or decay time, then I am perplexed as to how people talk about using cables and soft suspensions, or transformer coupled amps with a low damping factor, as if it is anything other than describing the danger fleas and ticks on an attack dog.
Both the box “order” and crossover “order” can store a lot of energy.
When those are hit with some impulse, it takes longer for that energy to decay away.
In a planar speaker we can attribute that to light mass, but it is also a 1st order “enclosure”. A big driver in an open baffle is also a 1st order “enclosure”.
I suppose that one can try to loosen the grip on the driver in a lower order box.
(I am discounting whether that is the right thing to do or not.)
But it is difficult to increase the grip on a driver, when the box and XO are high order. In that case we are gripping onto the XO and the box has largely evaded our grasp.
In any case if PRAT may not be something that is trying to describe transcient and impulse response, so I could be wrong.
I think I was relatively clear, that having the speaker sucking-n-pushing, with an impulse or step function response that is all janky, sort of does not match the outgoing sound wave to that which the microphone recorded.
If there is trident shaped impulse response of correlation peaks, then does that make for a system that has PRaT?
I think that post #133 showed the impulse or step functions:
I don't know who/what you classify as competently designed? Do you consier the big name speakers as competently designed? e.g Magico, WIlson, YG, Avantgarde, Goebel, KEF, B&W ....
I pasted three pictures of impluse response as measured by stereophile. One is almost a perfect triangle. This one is from an old Thiel model. It used a first order crossover and all of the impluses from the various drivers arrived at the same time. But only on one axis. If you shift the axis they won't arrive on time as is shown in the second picture. The third picture shows a well known speaker brand reviewed in 2024. We can see that the tweeter, midrange and woofer arrive at different times. And that the midrange is even out of polarity with the tweeter and woofer.
I don't need to do math. I can hear it. Whether it is the speaker or the room I don't know and it really doesn't matter. The fact is the instruments are either playing together like a band or they are not. This is the definition of praT.
It might be more nuanced than just even versus odd, and the SS having odd and tubes even..
Some of those amps have just 2nd and 3rd order harmonics, and very little happening in the higher harmonics.
It is not just a hand waving, “these are not the droids you’re looking for,” where everyone is just assumed to know it.
The statement seems like it was couched in terms as some fundamental law that came off the mountainside carved on a tablet, and while I have heard it for decades, some systems just sound scary quiet and relaxed.
(Maybe that is the opposite of resolving? And why a lot of people have other systems.)
Back to @Robh3606 his cherry picked plots on his post #139.
How is my feeble mind supposed to work out, in real-time, which of those peeks/peaks is/are the one that describes the sound coming in
There are two or more options for that waveform to give me some PRaT, and I sort of need it to be clear, in order for me to get it.
And if the sound is further delayed by a cycle, then that is also making it difficult to line things up.
It might be possible that some people are just better at processing the sounds, and others need some help with an easier and more accurate sound?
Some speakers may use a full 360 out of phase alignment but you're cherry picking examples to make your point.
I don't think the vast majority of speaker manufacturers simply don't know what they are doing wrt to time and phase, and I don't think this subject has anything to do with PRaT either.
I think I poised one of my earlier posts as a question… “as to whether impulse response was what PRaT was trying to describe.”
So I appreciate your response, that you don’t think that it has anything to do with PRaT.
The good news is that almost everyone has gear that they are able to enjoy, and the industry caters to many people.
I dare you to come here and call my bottom soggy to my face! ;)
Reactions: Lagonda and Holmz
Perhaps a definition of what is a 'good speaker' is in order. From the perspective of tubes, a good speaker will not have low impedances or obtuse phase angles (if you see what I did there) in the bass. Instead it will be 8 Ohms or more. We have to also be careful about what is meant by 'a tube amp' as they are not all the same! Some tube amps have full power bandwidth to 1 Hz while others struggle to do full power at 20Hz. Others have THD of 0.0015% with IMD of 0.005% with 80dB of feedback. So I regard your statement as a bit of a generalization although I know exactly what you're talking about.
Now if you plan to run a solid state amp, a 'good speaker' will be exactly as I described above. I just hate the bright harsh sound you get from a good speaker being driven by a solid state amp, the distortion is fatiguing and I can't listen to it long.
I should qualify 'solid state amp' as one that has the typical distortion rise with frequency that has plagued solid state amps since their inception. These days there are solid state amps that don't have this problem and so are a lot smoother and more engaging.
IOW despite the Voltage rules that were adopted for driving speakers in the late 1950s, its still important to match the speaker and amps together for best results.
I would like to add that most speaker designers are making "poor" trade-off's in my opinion. They are trying to say they play "full range" and go down into the 20's Hz. This is market driven as people believe that if I have a big box then I should have deep bass. I think much better sound could be achieved by trading the bass extension for higher efficiency. Also, as you say, they should have higher impedance as well. If the person wants bass extension then get a pair of subwoofers that are specifically designed by the manufacturer to mate with the speaker and handle below 40Hz. But what do I know ??
I hate to admit it, but I kinda like a cute phase angle myself.
Yes, you find a speaker you like and then you pick a amp that can drive it properly. If the speaker manufacturer makes the amp for this purpose, there is a good chance it will work well. Many modern SS amps sound wonderful and don't get bright/ harsh while doing this, i still own 35 year old SS amps that possess these qualities and have never failed once in all those years. :)
Preventing a rise of distortion with frequency in a solid state amp 35 years ago was pretty well impossible. The Gain Bandwidth Product needed to support the feedback was very hard to obtain.
Luckily there's a TON of speakers on the market, you can choose one that has a design that fits your own priorities.
I think most modern HiFi gear is well designed, the days of incoherent speakers and bright SS amps are largely in the past. That doesn't mean everything is designed exactly how you'd like it, or is perfect, but the degree of competency is very high compared to what it used to be just 20 years ago.
