Innuos Zenith 2For anyone who has a KTE May DAC:
What streamer are you using with it?
How does it perform sonically when converting Qobuz to analog?
I have only had the May DAC in the system for a couple of days.Innuos Zenith 2
Sorry for the delay, I didn't get notified or missed the notification. I use a powerful 10 core Intel based dedicated custom fanless Sigao media pc based solution from the UK at www.atlastsolutions.com along with a 300w linear power supply from HDPLEX. I'm using Roon software along with HQplayer. Over USB I've tried DSD512 and PCM 1.536mhz or 1.4112mhz depending on what the native bitrate/bitdepth. DSD512 is very good, but to my ears I prefer the PCM upsampling over DSD512 slightly due to a very slight increase in overall detail while DSD512 comes off a tad smoother, but still very good.Thanks for your impressiions wh01sjongalt.12244. May I ask about the way you use your May? Do you feed it with PCM or DSD maybe from HQPlayer? Also maybe you would like to share with us some names of your other best measuring DACs before getting the May?
I use a custom fanless powerful media server solution from the UK (~$2K)For anyone who has a KTE May DAC:
Hi Bluedog Happy NEW YEAR buddy.Innuos Zenith 2
Nice to hear your experience with the Holo Spring May KTE. After listening to a lengthy demo of the MSB Select several years ago, I was hopelessly floored. Then after hearing the Spring KTE it became clear that possibly I actually might be able to afford a competent R2R. And now the May, most intriguing...Hi guys, Have not posted much in some time, but think this Dac is worth posting about.
I've had the May in my system for almost 4 weeks now. I traded in my Holo Spring 2 KTE Dac for the May KTE version. Had the Spring 2 for about a year. I have about 400 hrs on the May so far.
I'm using a I-9 SonicTransporter for a music server with Hqplayer as the player. Usb cable is an Intona Ultimate. Still using Innersound Kaya loudspeakers, but now use custom made active crossover with copper chassis, z-foil resistors, and various highend caps. Innersound amps still in use. Added two Rel G1 mk2 subs, and ELAC 4Pi Plus.2 super tweeters roughly a year ago.
The May is a very quiet Dac. Not just for an R2R, but for any kind of Dac period. Had a Mola Mola Tambaqui Dac before I got the Spring 2 and the May is right up there with the Tambaqui in the SNR department. The Tambaqui was very good, but was ultimately too fatiging in my system. The Holo dacs on the other hand are not fatiging at all. Which is very hard to do without sounding boring.
The differnces I hear between the Spring 2 and May are these. The May is quite a bit quieter. The May also does the frequency extremes better and is more resolving of detail. Stereo separation is noticably beter as well. The May is dual mono construction with a separate power supply, so that makes sense. As far as tonality between the two it is very similar.
Other dacs I've had in my system lately are the Yggy 1, and the Emm Labs DA2. Had the Yggy for a couple of years. I liked it and it compared favorably with the Spring 2. Only had the Emm Labs DA2 for a couple of days. Sounded lovely with PCM, but DSD was behind the Spring DAC by far. Decided to stick with the Spring at that time. Wonder how the mk 2 version of the DA2 sounds?
Anyway that is my 2 cents so far.
TLDR: I've never heard a more natural, holographic, and realistic sounding DAC, ever!Too bad that the USB input on the May was not tested (and compared to the one in the Tambaqui). Also the use of HQPlayer can have stunning benefits as I have experienced yesterday for the first time with my little Chord Mojo connected to an OpticalRendu. With HQPlayer upsampling of redbook CD files to DSD256 fed to the Mojo, this little DAC delivered amazing sound quality. Hard to believe without experiencing it first hand. Thus, I keep wondering how much closer the May would get to the Tambaquis physicality and 3-dimensionality with HQPlayer at work ... then OTOH the Stereophile measurements of frequency response of the May when fed with native DSD show a somewhat fast roll off so that the Tambaqui will most likely stay to be the more open sounding DAC.
the Yggy also has had the analog 2 upgrade, firmware and the unison USB upgrade, the latter which I found to be better than the AES input.Too bad that the USB input on the May was not tested (and compared to the one in the Tambaqui). Also the use of HQPlayer can have stunning benefits as I have experienced yesterday for the first time with my little Chord Mojo connected to an OpticalRendu. With HQPlayer upsampling of redbook CD files to DSD256 fed to the Mojo, this little DAC delivered amazing sound quality. Hard to believe without experiencing it first hand. Thus, I keep wondering how much closer the May would get to the Tambaquis physicality and 3-dimensionality with HQPlayer at work ... then OTOH the Stereophile measurements of frequency response of the May when fed with native DSD show a somewhat fast roll off so that the Tambaqui will most likely stay to be the more open sounding DAC.
Sorry Shill, I missed your New Years postHi Bluedog Happy NEW YEAR buddy.
Sincerely,
Jonathan aka Shill
Congrats! I keep mine vertically separated between two shelves just because I can and it couldn't hurt and may prevent accidental scratches or what not, but not for any audible reason. It measures perfectly well stacked and the benefits of isolating the dual mono lps in the separate chassis from the ladder dac section is more than adequate in achieving this goal. It's 40lbs total weight so maybe separate shelves is safer though. If you can do it than I wouldn't hesitate to separate them, but not for sonic reasons per se.I've got a May L3 on the way. Has anyone found any reason to separate the PS from the DAC vs. stacking them?
I have wall mounted shelves for all by my amp and can easily add one more to separate them by a few inches. It seems that some space would certainly not hurt but may not help either.
I've listened closely to the May KTE stacked and unstacked, and have not noticed any difference.I've got a May L3 on the way. Has anyone found any reason to separate the PS from the DAC vs. stacking them?
