How much impact does driver material has on SQ??
AudioGod
Active Member
Aug 27, 2023
267
136
43
44
Finland
Some speakers use exotic drivers and some use "simple" drivers
The exotic ones don't always sound better
But I must admit Beryllium tweeters sound the best to me.
So I'm not so sure how much impact the driver material itself has on the sound quality .
What are your thoughts on the subject ?
It can matter. A lot. See this from Vandersteen
Reactions: ecwl and AudioGod
And one other thing….
There is an audible benefit of using the same materials for all drivers (except subs). My two favorite speakers do this - the Vandersteen Model 7 and the classic Zellatons
Reactions: AudioGod
I would say it all matters ( in the case of a cone: cone material, surround, spider, magnet type and size, voice coil design etc. ) but that doesn't mean that different designers wont have different preferences as they tackle all the compromises towards their goals.
iow hard to say whats best in many cases
Well both ESL and Ribbon panels are not pistonic , then again they have bad sounding midranges , Vandersteen maybe correct ..!
Reactions: AudioGod
The midrange of my DIY horn speakers is an AER BD3 in an Oris 150 horn. The AER driver has a paper cone. I might deluding myself, but I find the SQ it produces to be very good, fast, coherent, tuneful, with great transients, etc. I have tremendous respect for Mr. Vandersteen, but I feel that in this particular case he is painting with too broad a brush when he condemns all paper cone drivers.
Reactions: AudioGod
With Dynamic drivers treated paper is still the best for midrange ...
Vandersteen is way off IMO as many of these wonder material drivers are so bad when operated out of bandwidth , that magic wonder xovers are needed making for clean and clear but very Hifi sounding products ..!
To each their own ...!
Audiohertz,
What components and speakers do you have in your system?
Reactions: AudioGod
Any driver materials that absorbs moisture or changes in temp has inherent issues
so while I can’t say I have a fav in a given type materials I think over all cross overs used has a big effect as well.
Reactions: AudioGod
I have no idea if I like paper or composites. I have never heard a speaker with either material to swap back and forth. To hear one or the other in a different box with different crossover, different amp, different toom. Pretty hard to draw any real conclusions.
I do have PAP trio 10 and 15. The 10 woofers/midrange are a composit. I like the 15 a whole lot more. But there is a large size difference.
Reactions: AudioGod
I’m audio many look to new age materials in the hope to attract buyers on new tech merit
be it better or not. alum woofers as an example some say they ring I’ve never measured
but stiffness and lightness does have merit
they all need to move air right but air is very variable
In density so what is best ?
to me room first then speakers but it can be done opposite either way the amp must drive them well to given loudness. This makes me feel materials used has a large effect on room size and seating
Reactions: AudioGod
