Thank you very much for your description. We exhibited with the London at the California Audio Show in September (www.lotusgroupusa.com) using SW1X Audio Designs tube equipment and PranaWire cabling. I found the London in to be spectacular loudspeaker. A friend of mine walked in the room and after a minute said, “The bass…it’s like velvet with a punch.” That punch I would add was always in the service of and appropriate to the music being played. We used no room treatments, even though they were offered to us. They just weren’t necessary.A bit late commenting here, having just been told about this discussion.
I guess there’s little WVL user input since all will be too distracted by music to be here in front of a screen!
I’m a dealer in New Zealand & first landed Wolf von Langa’s SON in 2020 with the idea of stocking a higher efficiency speaker design in compact enclosure. You could doubt how a tweeter integrates so well with a 12" driver on first seeing the SON - Wolf certainly succeeded, no doubt due to constructing purpose-built drivers in house. SON greatly exceeded my expectations, proving flexible in placement and giving me the confidence to stock and use a demo pair myself until ordering a pair of Chicago in 2022. Those are not much bigger in footprint and in no way imposing for a dual 15” open baffle.
Speaker location isn’t betrayed in the spread of soundstage - being very wide and deep. Chicago energises air between speaker and listener, presenting realistic midrange with greater body and nuance over the SON. Combined with room voids, glass, flexing wooden floors I get no boom, but little room-bass gain in this space. Speaker placement is critical along with alignment to reduce room resonances at the listening position without excessive use of room treatments (apart from records which are of course essential). Placing the Chicago in this difficult room was a greater challenge but I worked out solutions over time. I’d ordered the top mounted AMT but just couldn’t get that to work with a low ceiling and closer listening distance for this space. The room & high tweeter position presented a phase issue only solved by installing the AMT into the mid baffle as on previous versions and adjusting the angle.
I’ve found Chicago more tolerant of lower-watt amps & despite similar looking efficiency have more drive/ higher volume capability than the SON. Individually adjustable upper and lower 15” bass on U-baffle provide delicacy and impact when needed. Audio Frame design and crossover jumpers offer a number of possibilities for mid and tweeter adjustment. My office desk is behind the speakers, where I can also enjoy music - another benefit to open baffle. To tame resonance in that alcove a small amount of Mundorf Angel Hair is placed behind the midrange frame and some other damping on bass frame walls. From delivered setting, there’s a narrow range of adjustment in field coil current for correct bass/ mid damping: useful for amplifier matching.
It may seem a stretch to call the Audio Frame series a bargain but I’d go further and call it a gift from the designer. Wolf has dedicated decades to designing field-coil motors and paper-silk drivers from a deep appreciation of vintage audio and a commitment to overcome past compromises. I can relate having been a collector and user of a wide variety of speakers from high efficiency Altec & JBL, vintage Tannoy, wideband drivers from Klangfilm to Lowther (Accustats, Quads, also many more recent speaker types both owned and traded-in). I've no interest in headphones, vintage speakers or others since using Audio Frame Chicago in my personal system.
Congrats! I’m a happy WVL customer (custom field coil power supply) and use Dueland caps in my own horns, so I “get it”!Just upgraded my SONS to the new WVL ULTIMA! They are SONS on steroids! Much more articulate nuanced.
The ULTIMA uses an upgraded cabinet with the same dimensions as the SON with upgraded crossover components including Dueland capacitors and a much upgraded PSU. The field coil utilizes a new winding technique and chassis.
One happy chappy. Thanks, Colin!
There really isn’t. Only a spec sheet. It is known as the WVL 12739 ULTIMACongrats! I’m a happy WVL customer (custom field coil power supply) and use Dueland caps in my own horns, so I “get it”!
Is there a link with more information on the ULTIMA? I don’t see them on the WVL site…
Thrilled you're loving the ULTIMAs. They're such amazing loudspeakers.One happy chappy. Thanks, Colin!
ULTIMA is a new model that completes the evolution of the STAGE and SON family. We're finalizing all the website content and informational material; I'll have more soon.Is there a link with more information on the ULTIMA?
Will you display Ultima at Axpona 2024?ULTIMA is a new model that completes the evolution of the STAGE and SON family. We're finalizing all the website content and informational material; I'll have more soon.
I can say that it takes an already remarkable loudspeaker in the SON to a significantly higher performance level while retaining the same lovely form factor. I'm very excited about it.
The website is a bit random. If you specify English as the language the Wagyu subwoofers disappear altogether.
Perhaps they only sing in German?
They do have a bit of a translation issue as well...not the most intelligible descriptions.The website is a bit random. If you specify English as the language the Wagyu subwoofers disappear altogether.
+1Any person has experience with the new WVL WAGYU subwoofer? Especially in tandem (or used together with) any other WVL speakers?
Didn’t last long in Colin’s house…in mine now!I can't wait to hear them Colin. I'll bet they will sound amazing with the Trafomatic Rhapsody parallel single-ended integrated (20 SE watts per side) you will have in house soon. I'll be headed to Florida this month and will do my best to visit Nashville to hear the pairing for myself. In the meantime, I'm absolutely loving my Son's but realize the Ultima will add a whole other set of gears!
Sorry for the car talk boys - been shopping for a car the past month and that's cluttering my brain![]()
Congrats on your purchase! Enjoy!Didn’t last long in Colin’s house…in mine now!
