What did you think of them?I auditioned Sons in my room. The pair I auditioned had these legs.
The Sons are short, so the height helped the sound.
No, only with the legs. I like tall loudspeakers.So you tried them with and without the legs ?
I did not see threaded inserts. Actually I did not care at all for how they were attached. Each leg is attached with three small screws. The attachment method looked appropriate for a lightweight coffee table, not for a heavy loudspeaker. I would've preferred a much more robust attachment method, and much heavier, sturdier legs.Iirc they have threaded inserts for attaching footers. Maybe no modification were needed to allow adding the legs. Smart move on Herr von Langa's part.
Hi Ron, heads up that the set of CONICA (official name) stands you saw was a preproduction prototype built for a show and not representative. I think you'd be pleased with the fit/finish and heft of the actual product. Ask David for his thoughts when he returns home.No, only with the legs. I like tall loudspeakers.
DavidAVDavid, who has Sons and loves them, has confirmed that he prefers them with some sort of riser.
PS: I like the Sons a lot. I have liked every field coil implementation I've heard (WvL, Classic, Songer, Treehaus) except the small Audio Note.
Excellent! I am delighted to learn this!Hi Ron, heads up that the set of CONICA (official name) stands you saw was a preproduction prototype built for a show and not representative. I think you'd be pleased with the fit/finish and heft of the actual product. Ask David for his thoughts when he returns home.
IMO, everything Wolf von Langa releases is absolute top quality.
Hi RonExcellent! I am delighted to learn this!
Thank you for weighing in here, Colin!
Yes, everything I have ever seen from WvL is indeed absolute top quality, which is why I was puzzled about those legs.
Hi!Hi Ron
Seasons greetings ☺
May i ask,
were you not tempted by a pair of Chicago as your main speakers?
Beautiful system. How are you crossing over the Tektons?
How are you finding their bass performance, 40Hz and lower? Do you consider them full-range speakers?The Wolfie Chicagos continue to impress. It's been a rewarding journey, with placement, pairing of upstream equipment (ALL is revealed by the Chicago, and I do mean ALL), installation of the footers, and finally careful adjustment of the FC controls. Every step has raised the (already amazing at first installation) performance of the speaker. Each time I think I've reached a performance ceiling, I learn otherwise. Stay tuned, next comes the installation of the LAMM preamp, SW1X monos and possibly the WVL horn-loaded sub! BH @gestalt
Thank you. I’m using the Tekton internal crossovers at 40 hz The subs are also set VERY low in terms of volume. For me, they are there to help recreate the “space” of the venueBeautiful system. How are you crossing over the Tektons?
I’m still working to coax the best from the bass using the field coil current adjustment but as specified they seem to do nicely standing alone into the mid-30’s with amazing speed, clarity, and articulation in the bass registers.How are you finding their bass performance, 40Hz and lower? Do you consider them full-range speakers?
I see a pair of tube amps and a stereo amp - are you driving the WvL in biamping?The Wolfie Chicagos continue to impress. It's been a rewarding journey, with placement, pairing of upstream equipment (ALL is revealed by the Chicago, and I do mean ALL), installation of the footers, and finally careful adjustment of the FC controls. Every step has raised the (already amazing at first installation) performance of the speaker. Each time I think I've reached a performance ceiling, I learn otherwise. Stay tuned, next comes the installation of the LAMM preamp, SW1X monos and possibly the WVL horn-loaded sub! BH @gestalt
I've tried multiple permutations and possibilities with the Chicagos and the process is ongoing. I've tried my beloved VTL Deluxe 140's (in Class A triode mode) biwired to the WVL's as well as a pair of PS Audio M1200's. I've biamped with the VTL/M1200 combination as well, and most recently installed a New Audio Frontiers Stradivari preamp and Stradivari 211 SE stereo amp. The NAF combination may be the "best" if by "best" one means most musically engaging.I see a pair of tube amps and a stereo amp - are you driving the WvL in biamping?
I also have FieldCoil (SupraVox). What exactly is regulated with the WvL power supply units (current or voltage or both) and in what range?The other issue is adjusting the field coil energy, which has dramatic effects on the sound.
