Positive, constructive dialog can't take place if there is a failure to comprehend what is written.
Thank you for clarifying your position. I now know "the truth".
There are no controlled tests on tube burn-in either. Do you also discard tube burn-in?
BTW, his big name clients likely don't give two hoots about "burn in".
And how do you know this about Mr. Meitner?
Different applications, different requirements.
Sorry I wasn't clear. That's what I was asking. How do you know if Mr. Meitner's clients don't care about burn in?
Depending on the studio client, some may be very concerned about break in and its potential impact on sound quality. Seems to me that sound quality could be a very large, pressing and important issue in a recording studio.![]()
I said different, did not say more demanding. Do the spacecrafts have stereo systems?No not in this case exact same application we are taking wires and cables. If you mean audio is a more demanding application you couldn't be more wrong.
Rob![]()
Hello Bob
Please explain the science of dielectric burn-in?? I work in the electronics industry and have been screening components for use in manned space flight and satellites for over 30 years. Part of screening for the components is burn-in but we are talking resistors, capacitors, inductors and all active components. Do you know how much burn in wire and cables get?? Zero, it is used right off the spool. So if no burn in is required to fly in space because there is no significant change why is it needed here??
Rob![]()
Sometimes the listener's mood, etc, will be a factor - but not always. A telling situation is when one is feeling very out of sorts, for some completely non audio related reason - but this doesn't make the audio playback come across badly, if it's working well.The system sounding better or sounding worse can be explained by the listener, being in flux, changes in mood/state of mind, health, expectations, any number of biases etc. The "other factors".
One moment the system is sounding great, the next it sounds different, not great, but different ... could it be that the listener - the ear/brain interface (where all the post processing effects take place) are responsible? If not, why not? If not, what controls were in place to prevent them from influencing the listening results?
The burn-in commonly carried in the electronic industry is usually carried in different conditions and with different objectives from audiophile burn-in. The burn-in or artificial aging of components is usually a measure to minimize early failure rates.
However, some manufacturers also burn-in components, such as precision resistors to make them long term stable - a clear indication that something physical happens during the burn-in phase.
Hello Micro
Basically it is to weed out early failures but it is also done to verify that the parts basic characteristics are stable over time.
I don't think anyone denies that there are measurable changes in the parts. That said in my industry we test the heck out parts between qualification and part screening to verify part stability. If you look at any of the component specs any delta requirements are done between the mid point of the burn-in and final test. The majority of the changes happen early on and typically a part is stable after the first half.
Not so with wires and cables. There may be a few feet of wire that gets tested on a spool but there is nothing done to the balance.
So what is audiophile burn-in??
Rob![]()
Can I conclude that you accept the typical audiophile burn-in of components and equipment, and are only questioning cable burn-in?
Hello Micro
Rob![]()
Hello Micro
No not really I am very skeptical. Here is the rub, parts do change over time and temperature but usually not enough to take a part out of it's tolerance range. My gripe is even with accelerated aging, which part screening does do, the parts are typically still in tolerance. So if you have a 5% resistor it will still be a 5% resistor after screening but it will have a shift in value. If the design can tolerate a 5% part then this shift in value should not be audible. Basically you can have a 10% value change from resistor to resistor right out of the box. This is much more than you would get after a couple of hundred hours of operation. You have to remember that in any application parts are not used close to their max ratings for reliability. In part screening you are intentionally hammering them to weed out potential failures. So in real world applications you should see even less change than screening.
You have hundreds of parts all shifting slightly in value that all interact with each other. Why does it always go well. Especially when part tolerance swamps any part value shifts due to "burn-in".
Rob![]()
