Exactly what was done here, maybe I should have contacted you first about the power supply and motor controller Francisco!
Right now the belt is so loose that it's almost falling off, barely catching and it still sounds full bodied and solid. I only got the finished motors a little over a week ago and I'm still learning more about them.
david
The german company who manufactures your controller has an excellent record of reliable and well engineered products, you are in very good hands.
The static friction coefficient is usually significantly higher than the kinetic one - if you avoid belt slippage at the pulley and platter you possibly can get faster startup. The technique is increasing the motor speed progressively - it should be possible if the designer knows the full system pretty well. Sometime in the past I drove the synchronous motor of my turntable with a laboratory sine oscillator - the platter started very fast because I increased the driving frequency manually - after some time my hand become trained and I became an excellent startup controller.
