short and sweet for your mobile phoneit will be very simple to avoid words and just post videos of 200k plus speakers you think are sounding good in that system set up.
Not for you sport
Not for you sport
Whatever you sayAgreed, if readers hear the sound that comes out of those price tags no more sport.
Physics is the reason typicallyWe don't talk about them collectively as often as we should I think because many people in the USA have not heard any of them, but I think the Goebel Divin Majestic sounds anazing! The Divin line is relatively high sensitivity, relatively few drivers (3-ways) and relatively simple crossovers.
The larger the model, the higher, the sensitivity:
Majestic 98dB
Noblesse 95dB
Marquis 92dB
Majestic 98dB
Noblesse 95dB
Marquis 92dB
Majestic 98dB
Noblesse 95dB
Marquis 92dB
Yes Howie had those with Kida K70 (which he chose over Goldmund and Engstrom), he also did a video shoot for the forum, which accurately reflected his in room perceptions.
He then moved to Tannoy Westminster, and then to AN-E and is very happy.
Our local Wilson/Magico distributor is also a Devialet distributor. I have listened to all of them side by side. I know why I prefer the "boutique" high-end speakers.
Dave Wilson rolled over in his grave.Yes I know. But the way you wrote it was too tempting.
Exotic birds require research. Wilson is like Coca Cola, [emphasis supplied] arms length distribution.
This is a very interesting data point, and an interesting progression. I, personally, do not understand this progression at all. For me personally I would lose suspension of disbelief with each step to a smaller speaker.
Are you sure it has nothing to do with downsizing residence or downsizing listening room? That could be an independent variable, which renders meaningless any assumed implication of this progression.
Overall sensitivity of speaker can be meaningless if upper drive is 16 ohm, the woofer is 4 ohmsand there is an impedance drop to 1.5 ohms somewhere along the way, and correction for a hard phase angle, or 4 drivers with differing characteristics.
I find it funny when someone using a speaker with limited bass capabilities, but great sound, advertises the virtues of a small high tech offering with great numbers on paper. When are you getting your own Phantom Gold speakers ?Hmmm.. just wondering why a loudspeaker like the Phantom Gold that can reproduce a 14 Hz bass signal at 108 dB is called “puny”. Could you name me one speaker from a boutique brand like Magico or Wilson that can do this? I use a Klipsch La Scala, which can easily reproduce a signal at 120 dB, but the La Scala will not go below 50 Hz or so by design. It’s intended to be a low distortion design. Unlike boutique high end speakers that have massive distortion in the bass, the La Scala will reproduce a 50 Hz signal at 110 dB with 0.1% THD — don’t try that with your Magico, you’ll have a large repair bill for blown woofers. But the La Scala will not go lower.
To reproduce 14 Hz sub bass notes at 108 dB, Devialet used experts in the physics of explosives. I can assure you Magico or Wilson have no such expertise. They use drivers made by some other companies, they don‘t make their own drivers. Just because a Magico or Wilson is 6 feet tall and weighs a thousand pounds means nothing at all. It’s a question of physics.
Sounds more like degradation to me
I would be curious for you to hear outside of a show the Majestic or the Noblesse.
I think it is interesting to try to understand someone's genuine sonic preference. I don't see any value in insulting that subjective preference.
Model name confusion. Howie had the Noblesse.
The smaller Marquis I have heard in London with CH Precision, including the L10 preamp, and Monaco 2.0/Kuzma/Opus. We also did a Soulution 725 vs L10 compare there.
Roy Gregory will soon help set it up and I will hear again.
