Signature tailoring by iFi
The ZEN CAN Signature 6XX analogue headphone amplifier takes sonic tailoring to the next level with ActivEQ.iFi audio ZEN CAN Signature 6XX features a (bypassable) high fidelity active EQ synergistic with the amplification circuit itself to tailor the sound of the amp to the characteristics of the popular Sennheiser HD6XX (also suitable for the Drop HD58X and the regular HD580 / 600 / 650 / 800S) to bring out the best in them, plus a (bypassable) highly realistic analog spatializer for transforming your headphones into a spacious home HiFi listening environment.
iFi audio ZEN CAN Signature 6XX will feature sophisticated circuit design and high end components as also found on the Pro iCAN to produce class-leading results in the traditional measures of performance such as THD, noise floor, output power, etc.
Here's a bit of extra information we're putting here, ahead of even the Drop post. The correction curve applied by iFi audio ZEN CAN Signature 6XX will be as follows:
Specs
- Inputs: RCA, 3.5 (single-ended), 4.4mm (balanced)
- Headphone output: 6.35 mm, 4.4 mm
- Gain: 0 dB, 6 dB,12 dB,18 dB adjust
- THD+N (A-Weighting): 0.0066% (balanced), 0.0058% (single-ended)
- Maximum output power (16 ohms): 3.0 V / 600 mW (balanced), 4.0 V / 1000 mW (single-ended)
- Maximum output power (300 ohms): 15.1 V / 756 mW (balanced), 7.6 V / 196 mW (single-ended)
- Maximum output power (600 ohms): 15.2 V / 385 mW (balanced), 7.6 V / 98 mW (single-ended)
- SNR: -112 dB (balanced), -112 dB (single-ended)
- Dynamic range: -112 dB (balanced), -112 dB (single-ended)
- Frequency response (-3dB): 10 Hz – 200 kHz
- Function Button: HD6XX adaption and/or XSpace; Bypass
- IMD: 0.0098%
- Crosstalk: -50 dB
- Zout (headphone out): 0.25 ohms (single-ended), 0.5 ohms (balanced)
- Zout (balanced line out): 200 ohms
- Maximum power consumption: 13 W / 2.6A
- Dimensions: 4.6 x 3.9 x 1.2 in (11.7 x 10 x 3 cm)
- Weight: 1.87 Ibs (0.85 kg)
