Of course the dealer will tell you to buy longer speaker cables. More money in his pocket!
For most cables the difference in price will be small. Some ICs are almost a pricey as the speaker cables and in the particular case of Kubala Sosna the price is exactly the same!
The policies of pricing additional length are very different between brands - if you need long cables it is a factor that must be considered when planing and choosing our systems.
BTW, it would be nice to know what is John preamplifier and amplifier. IMHO the answer to the main question depends on it!
In the worst case scenario with matching pre, IC and amp the effect should be nothing more than a slight softening of the top end. At only 4m, I doubt many would here that. If it could, it isn't something a little bit of speaker placement play might fix.
Long ICs are usually only a problem with a tube preamp that doesn't have a cathode follower or SS buffer to lower the output impedance. John is using a SS preamp and 12' of ICs is nothing.
John, if you really like your VLab/King speaker cables, then they are the best cables for your preference. When I worked in statistics, I was told "There are lies, damned lies, and there are statistics." You can make the numbers "prove" anything you want.
