In search of the best rca cable
spiritofmusic
14,605
5,413
1,278
E. England
Marty, check out the red and black Magma emblem next to the Crimson King.
gadawg58
219
213
150
Zappadaddy ... my system is wired with MIT Oracle SC and MA IC. The MA-X is better and since my cables are a bit older now the newer generation is definitely better ... also very expensive for sure but I had a full Shunyata loom before with Anaconda IC and Sigma SC and the MIT was better in every way in my system. That said I have a friend who has Shunyata in his system and we agreed the Shunyata had better synergy with his system so definitely try several cables out before you buy. Good Luck and let us know what you decide!
George
Reactions: Zappadaddy
Cellcbern
1,222
726
585
70
Washington, DC
Zappa, scores of audiophiles have listened to dozens of cable brands but describing their sound is only as useful as understanding the system in which they are being evaluated. In other words, what works for someone else is not necessarily useful for you. The best way to find your ideal cable is to try them in your system. That's easy to do with resources like the Cable Company who have a huge lending library. So many good ones to try. You've named several very expensive cable brands, I'd encourage you to try some far less expensive cables as well. Keep in mind that many of the recording studios and record companies that make the music you are listening to produce their products using cables such as Mogami and other industry standard products that are extremely affordable. You may be pleasantly surprised to learn that it might be more productive to spend the big dollars elsewhere in your system.
thedudeabides
2,127
651
1,200
Alto, NM
Hm, I thought they are people here owning extraordinary systems?
Are you flippin serious? Many SOTA systems on this site with many different wires. Some budget and some pricey. High price doesn't guarantee system synergy and musicality. To state the obvious, it's all subjective and there is no best. On a more positive note, if you want to audition a wide variety of cables in all price ranges, contact The Cable Company. They have a massive "lending library" for audition.
Reactions: audioquest4life
Zappadaddy
270
175
115
62
Czech rep
did I say pricey? No, I said extraordinary
thedudeabides
2,127
651
1,200
Alto, NM
Really????????? Maybe I misunderstood. Please reread your opening post.
You mention Ansuz, Stealth Indra, MIT Oracle Max, Nordost Odin, Transparent Opus, and Synergistic Galileo. You stated "any thoughts or experience with these hi end cables". If these aren't "pricey", please tell me what is.
Zappadaddy
270
175
115
62
Czech rep
I did not think I will have to explain why I like to purchase cable which is adequate to my equipment. I did not expect somebody will get offended by that. Sorry I did my best to safe money on cables, believe me. The Cable company is not in Europe so I do not have that luxury to try cables like some of you guys in USA. Anyway finaly I bought Ansuz C2, I could not return it, it is so good. It cost a lot of money but it is definately worth it. "Music is the best"
Reactions: knghifi
thedudeabides
2,127
651
1,200
Alto, NM
Glad you like your Ansuz and you should buy what's best for your system. Too bad Cable Company is not available in Europe. My apologies for any misunderstanding.
Reactions: christoph
christoph
4,660
4,058
825
Principality of Liechtenstein
thedudeabides
2,127
651
1,200
Alto, NM
Could be a real business opportunity.
knghifi
255
70
158
Congratulations on your cable! Cable is a sensitive subject. Perfectly OK to spend stupid money on amps, TT, speakers .... but your intelligence is questioned on expensive cables.
tarquineous
76
5
913
You are on the right track IMO. Stay with at least some Ansuz cabling and their power conditioner (s). If you run into" too much brightness", or the like, get a product such as the Akiko Audio Corelli. I have one and I had to turn the volume up a bit, but no brightness or edge. Just fuller and more musical.
I also have an MIT Oracle interconnect. It does its magic best with a solid state sending component. The next component downstream can be SS or tubed equipment. I find the MIT Oracle very even in dynamics from low to high frequencies, and sounding less like "wire", if you know what I mean. I can't afford all MIT Oracle at this time, so I use what I have from DAC to Preamp. Hope this is helpful!
BTW: Hemmingway, Skogrand and Goebel are horribly priced. They will gladly transfer lots of money from your bank account to theirs. Lots of cable makers are copying this tier bracket pricing. Good luck.
Cellcbern
1,222
726
585
70
Washington, DC
Have you listened to Hemingway cables? The top of the line models are obscenely expensive because of the gold content but the 2nd level Hemingway Z-Core Beta for example are more musical to my ears than any Ansuz model I've heard, and comparably priced. Ansuz are better than their Nordost ancestors but still a little lean for my tastes.
tarquineous
76
5
913
I have not tried Hemingway cables. I saw the price and ran. Then I saw the review at Stereo Times. I don't fully trust reviewers.
Gold containing cables seem to come and go. I've tried Gabriel Gold, Silnote and some Bybee products. Gold tends to darken the sound and can have a fog like presentation rather than crisp and clear. Works good for me on passive power conditioners such as Nordost QX4. Using gold in a cable sure does take experimenting by the makers. I bought some from a jeweler and tried it in the signal path before and after the coupling capacitors. I did not like it there, nor did I like pure silver. Copper sounded the best by itself.
With that mentioned, I would stay with Ansuz on the power side, other brands for interconnects.
Check Stereo Times for the brand of speaker cable liked more than Hemingway. It is a recent review.
Cellcbern
1,222
726
585
70
Washington, DC
Hemingway Z-Core Beta AC cable, which I found used for $2.5K is a revelation in my system. Not dark at all, and the fastest, most articulate, most musical and alive-sounding power cord I've ever heard.
Note that there is aldo a rave review of an older model at Soundstage Network.
Cellcbern
1,222
726
585
70
Washington, DC
Interesting review of another cable that like the Hemingway uses gold and silver alloy conductors and their own make connectors. I haven't heard Fono Acoustico but the description of their sound compared with Audience Front Row sounds like the difference I hear between Hemingway and Ansuz, except I hear no loss of speed or definition with the Hemingway - quite the opposite:
